darinz wrote:So a couple of questions.Anyone done this and not had to replace the crank and or rod?
Depends on how far gone it is. Realistically you should replace any thing that seems worn excessively or is too far out of factory spec.
darinz wrote:Can you machine the factory pistons to drop compression a bit?
No.You won't achieve your goal that way. You'll just be replacing pistons sooner.
You can play around abit with Singh(sp?) grooves but then you start getting into the "quench" area of the combustion chamber.
darinz wrote:Any ideas and anyone have a few spares part lying around if I need them?
If you need anything used but still within OEM spec, let me know.
I have a block that I'm boring out to 5000cc, so I have a spare set of pistons and rods.
I have more OEM parts than I'll ever need, so I let them go cheaply to any NICO member in the Q45 or VH/VK forums.
(I'm a big believer in karma, and given the fact that I have an amazing wife, lots of machines(toys) to tinker with, and a kick a** job, I try to help out as many people,(non-douchebags, just people), as I can, to try to pay the universe back for what it has been kind enough to give me.)
(EDIT: Sorry for the run on sentences. I haven't slept in 2 days due to pain.)
Modified by Raxephon at 8:02 PM 3/17/2009
