Hi gs,gs14racer wrote:I had a pic laying around
It goes all the way thru circled in red, the real question is where does it tee off to the portion circled in yellow
Its becoming clearer now - After the oil filter the oil runs along a passage located on the left hand side of the block. This is where the pressure switch is located. From there it travels to the area circled in yellow and then up to the oil rail circled in red. So basically the oil feed to the central oil rail comes from the rear of the block. Actually I think Mettler already mentioned this in his post.I like the idea of tee'ing into the oil filter housing and running an extra line to the oil rail through the front of the block. Looks to be relatively straight forward if your not using the aircon (otherwise the ac belt gets in the way).
Incidentally I spoke to another guy today who has run a bearing in a VH (either #5 or 6 he couldn't remember). The impression I got was that it was out of a sedate daily driver which had fueling problems -> bad oil
