goody90q45 »
https://forums.nicoclub.com/goody90q45-u31761.html
Fri Apr 14, 2006 10:44 am
Good News. Followed your advice, and after airing everything out overnight, put it all back together and she fired right up. Drove it around the block, spewing some black smoke and missing real bad and can't go much more than 30mph. Engine sounds fine with no strange noises. Looks like hydrolock was my problem. I'm really relieved that the problem was not a siezed engine.
Bad news. Still have the same symptoms but now with raw gas dripping off the exhaust manifold below the car at the PS cat. I probably had the same thing at work when she originally died but didn't notice it. Based on what I saw when I removed the plugs it looks like the passenger side is not firing and raw gas is pouring through the cylinders into the manifold (?). This time though I pulled the fuel pump fuse and ran the engine till it died to avoid another hydrolock incident.
I know I've got a lot of troubleshoooting ahead but this is all new to me. I've been reading a lot of posts and it looks like I should start by checking spark, or at least voltage out of the coilpacks since I would prefer not to run the engine. About the only thing I've done so far is check the ECU codes, got code 34 (knock sensor).
I'm can't find the troubleshoot for the power transistor unit in the FSM or on NICO. This is one thing all 4 cylinders have in common. Any advice would be appreciated.
