USC Justice wrote:oops, forgot to mention the LSD from a J30.
Good! Anything better than open diff.
USC Justice wrote:Why the 300ZX fuel filter?
It's just a common upgrade that many 240 people do. It's bigger and believe it or not cheaper. It fits perfect on 240 fuel filter bracket. If you haven't replaced your fuel filter for a while, try 300zx filter this time.
USC Justice wrote:The power brace I have gone back and forth about. Is it really worth it?
It just stiffens up the front end a little bit. Don't get it now. You can try it later if you feel like your front end is kinda loose.
USC Justice wrote:I have a set of 300ZX rear calipers sitting in the garage, just been too lazy/unmotivated to go to my favorite salvage yard to get the rest of the parts that are needed.
z32 brake parts are hard to come by these days. They are the first ones to go if z32 arrives at junkyard.
USC Justice wrote:RUCAs??? enlighten, as the abbreviation doesn't come to mind...
Rear Upper Camber Arm. Will you get S-Techs? I don't know how much drop you will have, but they allow you to adjust rear camber easily. You have to push out upper portion of rear tires out side after the drop. Stock ones will max out.
USC Justice wrote:Why the adjustable tension rods over the Energy Suspension ones?
You can adjust caster up to 10 degrees.
USC Justice wrote:The sway bars are NISMO. I had no idea they would be Green and neither did my parts guy. When they were delivered we opened the box, and his first words were "Damn that's Green." I agreed. Kinda neat looking.
Hmm.. I couldn't find s13 sway bars in Nismo catalog. I found s14 and s15 ones though. They use same sway bars. In the picture, they are grey as usual with no Nismo decals on them. Parts numbers are:54610-RSS50 Front 30mm 53% stiffer56220-RSS50 Rear 23mm 17% stifferDo you have part numbers? Whiteline used to have them in green, but they changed to grey BTW.
Looking good and keep us posted how your project goes....
