Back again... Rb26/30 Build - UPDATE 4/8/12
RRRRB
Car: 98 RB powered S14
you need to get some cams! i bet it would make a big difference... i just bought a 6766 anxious to see what it does...i wish i had 3 liters of displacement spooling it though
Shocker
Car: 89 240sxHB rb26/30
RRRRB wrote:you need to get some cams! i bet it would make a big difference... i just bought a 6766 anxious to see what it does...i wish i had 3 liters of displacement spooling it though
I'll see I'd like to see what the 6766 would do alone with a larger .81 a/r alone before I'd make that jump. I wouldn't go any bigger than stock base circle drop ins if I did.
RRRRB
i got the 1.00 divided T4 Vband housing with mine, should have it next week, combined with the CNC ported head it should make some good power
julio
Car: RB26 AWD converted S14
Shocker, did you ever change/modify your manifold to deal with the boost creep issue? Also, what manifold are you running?
Shocker
julio wrote:Shocker, did you ever change/modify your manifold to deal with the boost creep issue? Also, what manifold are you running?
Sure did!
Boost holds very nicely now.
The manifold I'm running is from a guy who calls his company ETM? I think that's what it says on it. He was from the AU, its equal length and cost me less than a grand new. Once I get setup in a garage next year and finish my masters so I'll have time I plan to start producing my own manifolds on the side.
julio
What size are the individual runners and wastegate? Can you tell my manifold has a boost creep issue too? I've tried all the usual tricks: softer wastegate spring, compressor as a boost source (instead of intake manifold), and not having wastegate being reintroduced into the exhaust, but no luck.
Shocker
julio wrote:What size are the individual runners and wastegate? Can you tell my manifold has a boost creep issue too? I've tried all the usual tricks: softer wastegate spring, compressor as a boost source (instead of intake manifold), and not having wastegate being reintroduced into the exhaust, but no luck.
Its a v44 tial. Ind runners are like 1.25 and WG's are ~1.4". My creep issue was 100% wastegate placement not seeing proper upstream flow to hold constant boost.
Whats yours look like?
julio
rhd-lhd-manifold-wastegate-fix-t496806.html
I have the same wastegate, but the length, path of the runners, and perhaps even the transition from the manifold seem to be worse than yours.
Shocker
Yeah that is bad, and basically how mine was before, all the flow from the exhaust gasses is rushing right by the perpendicular waste-gate ports and into the turbine housing causing bad creep issues. Its following the path of least resistance, you need to move your two waste gate pipes down like mine are, that will make the wastegate ports completely parallel to the exhaust gas path and provide sufficient flow through the wastegate providing proper boost controlling ability. Look closely at mine, you can see the WG ports are directly inline with the #3 and 4 runner.
julio
So the exhaust from only #3 & #4 are being bypassed to the wastegate? Its kind of hard to tell from that pic.
Shocker
julio wrote:So the exhaust from only #3 & #4 are being bypassed to the wastegate? Its kind of hard to tell from that pic.
Yes thats correct
J2fast
Car: 240sx
hey i have a Q? im trying toput my rb30 in the car now but cant get the motor to sit right in there. so what crossmember and mounts are you using? im using r33 xmember but idk what mounts to use.
Shocker
I'm using McKinney Mounts with custom 7/8" tall aluminum pucks and RB25 mounts (the aluminum part that attaches to the block). Even at that rate its a very very tight squeeze. See beginning of this thread from more details.
Shocker
Oh spring is in full swing, and the cars are back out...
Over the winter(actually over last weekend) I took the time to install a new Q45 3.69 rear end for longer gear ratios, oil vent mod, (machined my own fitting) and plumbed it to the sump, added subframe spacers and eliminated the wheel hop. I also converted my rack to a 100% manual rack and completely deleted the PS. I love it! I also am loving the new ratios what a difference, the car feels so damn good right now.
Lucky to have a buddy who owns a ZR1 to run.. we will rematch soon after hook up a 5 BAR external and I add a couple more lbs on pump and we find a longer runway. ;) no more limiter hitting aloud either from me...
[youtube]http://www.youtube.com/watch?v=lCcb5qzH ... ature=plcp[/youtube]
Hope you enjoy.
bmxarmy
Car: 1961 AMC Rambler
holy f***! Nice work against the ZR1!! haha his 100,000 car looks kinda shabby now! hahaha Pretty crazy that you run that strong with 2 less cylinders!
Carl H
nice, i love my 30...just need a different intake mani and bigger turbine housing.
EVILS14
Car: 1995 NISSAN 240SX SE RB25DET
What's wrong with your r.i.p.s.?
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
Its made for a RB20.
Shocker
Carl H wrote:nice, i love my 30...just need a different intake mani and bigger turbine housing.
Me too, wish I just started with it.. Arnt you running a 30r?
Carl H
yeah, still got the 30r w atp's 0.78 twin entry housing...its too small for the 3l and chokes it out past 5.5k, you can see power tank on the dyno graph.
phenomenal response tho, makes it a blast to drive cruise in 5th at 3k stomp it and by 3300 i have 14psi lol.
gawdzilla
Car: none
Carl let's trade. t4 1.06 twin entry 35r :) you're in MD now arent you? :chuckle:
RRRRB
your buddy must be loaded...haha
carl buy my 1.06 30r housing...
I cant wait to get my car done hopefully another month and ill be around 600whp on pump 92 :mike
Shocker
I wouldn't run anything smaller than a 35R on an RB30.. They need a lot of air compared to the 25/26 motors.. and in extreme cases the 20 like Carls jump. My car felt sooo much better once I got the 3.5" on it over the restrictive crush bent 3.0" old exhaust.. We will see what happens on the dyno here soon, but I have a good feeling a set of drop in cams and the new 6766 .81 a/r would easily gain another 50-80whp at the same boost levels on pump with my setup.. granted my exhaust manifold doesnt start holding me back with its smaller than ideal runners IMO.
I did another run yesterday with another buddy and his Kenne Bell 5.0 that went 600whp earlier in the year. Car is extremely nice and I figured it would be a really good race which it was. Enjoy!
[youtube]http://www.youtube.com/watch?v=kxdeyhLE ... ature=plcp[/youtube]
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
That looks like so much fun to drive!
RRRRB
awesome thanks for sharing, i do alot of this kinda racing when the weather is decent.. Id really like to see a cam comparison on this setup i bet it would make alot more power...
Shocker
RRRRB wrote:awesome thanks for sharing, i do alot of this kinda racing when the weather is decent.. Id really like to see a cam comparison on this setup i bet it would make alot more power...
You might get one.. just not this year.. lol
I do that type of racing occasionally, I'm not a huge advocate of street racing unless its in the type of environment shown in these videos.. where I'm not blasting past unsuspecting drivers.
RRRRB
i agree, we have a pretty safe group of people, everything from turbo corvettes to some really fast hondas... its good times
ST240
Car: RB30DET Nissan S13
'01 Nissan Pathfinder
Man you're really racing the big dogs now! You said you rebuilt it, what kind of internals are you running?
I can't wait to get my 26 head going. I'm going to be running a .86 divided T4 on the 6262. I think it will choke still but it'll beat the hell outta my .58 lol.
EDIT: How did you do such a good job of shaving the "RB26" off the front cover? Or is it aftermarket.
Shocker
The engine is a 9:1 custom weisco piston motor, stock prepped rods, arp rod bolts, stock main bolts, 11mm arp studs, acl bearings. It's pretty simple nothing crazy. N1 pump with collar, I just keep the revs down to 7200. The 6262 is a good turbo and will make you good power too.
As for the cover i just ground down and shaped the aluminum with a paddle wheel for hood clearance, and the old 26 logo. Then painted it after.
ST240
Wicked man thanks for the reply! I have another Q. I'm seriously toying with the idea of going back to clutch fan too. You arent running a shroud at all?? You said yours is custom. What exactly does that mean? I ditched my RB20 clutch fan and shroud long long ago, and I think tracking down another might be hard.
