dont ask me i'd have to look it all up.... Add Bubba to that listDasoupdude wrote:Listen to Ld,evil,jet,mezz,cwik,spitual2,bean, etc etc.
Also; listen to Led Zeppelin.
Based on this...ldstang50 wrote:Are you COMPLETELY stock? I only ask, because a cone filter will put you in street prepared (where you'll get destroyed) and a simple shift nob change puts you in SM2 (where you'll get destroyed).
..a shift knob seems ok.2009 Solo Rules Section 13.2, Sub-Section A wrote:Accessories, gauges, indicators, lights and other appearance,comfort and convenience modifications which have no effect on performance and/or handling and do not materially reduce the weight of the car are permitted.
I know its very minor..... a shift knob, but this a fight I got into at my first SCCA event, hoping to run BSP with my Evo, in tech they noticed I didn't have a factory shift knob and was moved to SM. I was pissed.BusyBadger wrote:
Based on this...
There are a lot of seemingly harmless, everyday mods that would get a car bumped out of Stock classification but Section 13 also has a load of accepted modifications that can be made to a vehicle and still allow it to run in Stock.
Exhaust components downstream from the cat (as long as it complies with Section 3.5 which is VERY SUBJECTIVE), slicone hoses, theromostats, brake pads, a host of suspension & shock changes, front swaybars, different wheels (as long as they're OEM size)...these are all allowed. COMPLETELY stock isn't as complete as it may sound.
Can't say that I blame you. Did you protest it? You should carry around a stock knob and if they call you on it and want to bump you, you could switch it back and them commence to running roughshod over the Stock entrants.ldstang50 wrote:
My protest was going out and setting FTD....2 events in a row.BusyBadger wrote:Can't say that I blame you. Did you protest it? You should carry around a stock knob and if they call you on it and want to bump you, you could switch it back and them commence to running roughshod over the Stock entrants.
My biggest complaint is not being able to run steel brake lines (and I've no idea what Nissan was thinking when they didn't make them steel, at least on Brembo equipped models). I'd also love to have a finned (cooling) diff cover but that's not allowed either.
I've been looking everywhere for better wheels in OEM sizes and have narrowed it down to Enkei RPFs or Oz Alleggeritas (if I go on the cheap side) and SSR Professors or Work Meisters (if I want to drop a bundle). If I could find a good deal on OEM track wheels I'd be all over it since I love the way the styling, they're light, and they're usually pretty cheap in comparison to the benefits they bring.
R350Zz33 wrote:....and is it ok to drift a lil?
Then go to a drift event. You go to showboat, the likes of you kill the very spirit of racing. I am ashamed to have the same badge on my car as you. Vids or FAIL. BTW you can't bet with money you don't have.R350Zz33 wrote:i know its not the fastest but its the most fun so if i go do i get the money ?
What? There wont be any smoke when your sliding through the corners...R350Zz33 wrote:i mean would i get in trouble for sliding around some tight corners since there will be smoke and such.
I just got home. Wow, a decent thread begun and almost ruined by Richie. As far as autocrossing, Richie might not be old enough yet for most sanctioned events. Most require being at least 18.Watermelonwarrior wrote:What? There wont be any smoke when your sliding through the corners...
