auto door locking
acetuner
Car: fuga 2006 450gt
Hi,I have a 2006 japanese fuga 450gt and this auto door locking when it reaches about 17km/h is bugging me. Anyone know how to disable it,or is this not an option.cheers Terry
EdBwoy
Welcome to NICOclub Ace!
First, I'll move your thread over to the Fuga & Infiniti M45 section as I've seen more posts from Fuga owners over there.
Unfortunately, the American market M did not receive and did not even have that as a factory option. I believe I saw some chatter some time back from people saying they desired that feature. I hope someone with the JDM cars can explain if it was a factory option there, and if it is something a dealer can disable with their Consult tool.
I'm curious to know, can you see anything related to it in the Settings - convenience menu on the screen? where it asks you to disable the keypad or global lock the doors
Also, does yours auto unlock when you park or do you have to turn off the car?
pedsemdoc
Car: 2013 M37 Sport - SOLD, Premium/Tech/Sport Journey
Carbon fiber engine cover
GT Spec front tower strut bar
R2C Intakes
Oil catch cans
Custom Start button LEDs
EdBwoy wrote:
Tue Nov 14, 2017 8:11 pm
My guess if that is not an available choice/option, you'll need a Consult III or later to hook up to change those settings or turn it off.
Larz
Car: 2019 Q70-L RWD
My 07 had the auto-lock and so does my 09. Both cars remain locked until the engine is switched off. Placing the gear lever into P has no effect.
EdBwoy
Anyone else? These are all the user settings my 08 has.
pedsemdoc
R2C Intakes
Oil catch cans
Somehow remembered this thread in the M37/56/Q70 forum:
post6719902.html#p6719902
I think this is an option that can only be adjusted by a Consult device.
acetuner
Thanks for all your answers,unfortunately every thing is in japanese on the screen.
EdBwoy
acetuner wrote:
Thu Nov 16, 2017 1:04 pm
We're gonna have to go old school - touching buttons and changing selections while comparing to a North American one to see what happens.
No idea where you are located, but people that got the RHD Fugas were trying to make some changes as seen in some of these threads. I don't how much they were able to decipher.
1. custom-english-m35-45-fuga-radio-button ... 20carwings
2. changing-japanese-buttons-t603435.html? ... 20carwings
3. english-for-2005-nissan-fuga-350gt-t592240.html
Does your voice control feature work, I guess only in Japanese too? Since the Infiniti has language options, I wonder if the Fuga can be changed too.
*If I spoke Japanese, I'd probably hook it up on youtube and walk people through the screen to explore options.
EdBwoy
I figured that it was something that needed Consult in the US like the Y51 M37 & M56, just didn't know what the JDM options were for the Y50 M35 & M45.
And Larz, I couldn't find anything about the automatic lock - unlock for the Y50 in the FSM, maybe you have an aftermarket module like KP technologies? :gotme
Does anyone else have this feature in an 06-10 M?
airmanhoward
Car: 12 M37-Current
08 civic lx sold
06 M35x Totaled
2000 S10 sold
Ford contour svt-sold
91 caprice-sold
90 & 93 maxima-sold
96 ford escort-sold
Auto door locking was not offered on the M class till 2010.
acetuner
Hi my next problem is that the speedo reads 16% higher than the actual speed (it is on 19inch rims but that shouldn't make that much difference) Is that something that can be re calibrated through a simple plug into the computer system or not.
cheers terry
EdBwoy
What size(s) are the tires?
acetuner
Hi, trying to find a post on removing instrument cluster in fuga. Where should I look?
pedsemdoc
R2C Intakes
Oil catch cans
acetuner wrote:
Fri Dec 01, 2017 1:45 pm
Don't think anyone has posted a How To in this or the M37/56/Q70 forum - but I know Larz has replaced his dash - it's probably several screws and clips/fasteners.
This has pretty good photos from a guy who switched the colors on his FX35:
http://www.twistedperformancetx.com/inf ... uster.html
airmanhoward
Car: 12 M37-Current
08 civic lx sold
06 M35x Totaled
2000 S10 sold
91 caprice-sold
90 & 93 maxima-sold
96 ford escort-sold
You don’t need to remove the dash completely to remove the cluster. Very easy
https://youtu.be/oxu-9Qji7jA
hellabuck
Car: 2006 Infiniti m35x
I have a non jdm 2006 m35 and since I've had it the doors autolock, it also beeps the horn automatically when I start it and reverse... I would disable these if there were options because the honking thing is really annoying and I'd rather lock my doors like a human
my dads 06 m35 doesnt do this..
hellabuck
Is there any serial numbers or codes on the engine I can match up to see if its original?
EdBwoy
It sounds to me like you've got a glitch. Maybe a module that isn't working right?
I'm not sure where the likes of KP technologies modules are usually installed, maybe somewhere behind the knee bolster under the steering wheel?
Might you have an autostart module? (Hit the lock button 3x, or the unlock)
I know the engines usually have the VIN stamped/ plated somewhere on them, but I don't think an engine replacement would affect your electronics in the way you describe.
Have you run the carfax or seen any records from Infiniti (those are free) maybe to see if anything has been done/ recorded?
hellabuck
Oh interesting, I do have a remote starter, never noticed. It doesnt work though so that explains the glitches. thx
EdBwoy
hellabuck wrote:
Tue Dec 05, 2017 2:53 pm
FYI, the owner's manual will give you where most of the important info labels/ stickers are.
Technical info section, so around pg. 9-11 or so.
[It can be found online too. Type 20xx Infiniti M owner's manual into your favorite search engine and you should see a PDF version]
EdBwoy
We're back!
After I got a car with the feature, then I found out how to disable or enable the feature.
It applies for 2009+ models
