It's a very easy decision when you consider how underpowered RB engines are. (hp per liter wise) Compare it to a CA18DET:
(Just using stock rating specs here)
RB25DET = 100hp/literCA18DET = 96hp/liter
Ok, so - lets say the CA18DET was to be a 250hp engine. It would need to put out about 138hp/liter to match that. That's alot of pressure for a small 1.8 liter engine...
So is it worth it to you?
Well.. now lets modify the RB engine a bit. Lets make it give out 138hp/liter like your CA18DET gives off with those mods you would put on it.
That would make the RB25DET about 345 hp. Realistically it would be quite a bit less.. but ALOT more powerfull than your *almost* maxed out CA18DET.
My point: The STOCK RB25DET is more reliable, bigger, and stronger than a CA18DET giving out 250 rated horsepower.
I always reason like this with numbers... because it makes it easy to understand. They're not super acurate numbers like I said, but you get the point.
CA18DET = stock underpowered 1.8 liter poop.RB25DET = stock underpowered AND as powerfull as your modded CA18DET.
You decide! You want to modify the 6 cylinder and make serious power? Or modify that puny 4 cylinder and try to catch up with the RB25DET?
