myidea7 wrote:OK Thanks, I got it now. Did you make your own adapter for the transmission or buy one? I have found a VH45 complete for next to nothing but I don't know if it needs a rebuild. I would at the very least like to put news bearings and rings in it, but I'm afraid to tear it apart bc I would have to have the cylinders honed for new rings (if it didn't have any damage to the cylinders and need to be punched) and how would I get it honed with the nikasil coating on the cylinder walls from factory and if it did have to be bored over, where are you huys getting pistons and are you having the nikasil coating put back on? Sorry for being longwinded just trying to pick your brain a little.
I bought a Mazworx adapter for my TT manual trans to mount onto the VH45 motor.
As far as the motor, try to find out if it runs or if it's damaged. With this kind of swap, you'll be pulling and installing the motor several times to get the positioning, clearances, etc. correct. If the motor at least runs try to get the swap completed and running, albeit poorly, and once you have everything right, then pull the motor and do the rebuild. Worse thing you want to have happen is to rebuild the motor and find out that the swap isn't going like you want/expected and you abandon the project - not saying that you would but it could happen. In that scenario you're out the cost of machining, pistons, etc.
I know about the moly coating on the pistons, but wasn't aware of the nikasil coating; if you want to just clean up the motor, I've heard that it can be done with a sunnen type hone. Not sure on how much plating there is though and how much material you're planning on removing so you may or may not be ok. As far as boring it out, I think someone on NICO has done it (made the VH a 5.0) and basically bored the sleeves out during the machining. They then re-sleeved IIRC - not sure if anything was coated though. If you go that route you can bore it to match pistons that will fit. In my case I'm planning on low compression pistons of the same size and will most likely custom order them.
There are a whole lot of people here on NICO with a lot of knowledge with these types of things, so maybe they can add their perspective to this. Hope this helps....
Thanks,Nick.
