qsiguy
1994 Infiniti Q45 Turbo
Phoenix AZ
3-20-2005
I absolutely love your car, wanted one of those since they were released. I'm in about the same boat as you with the job/family/wife situation so I know exactly how you feel!I'm a believer in the rear mount turbo setup so you have my vote there. Here's a link to my excel spreadsheet for turbo selection, I used the information from the Garret web site tutorials to make it. For twin turbos you just use 1/2 the displacement and HP goal. Sheets 2 and 3 of the spreadsheet also have information on them as well. It gives you a total of 9 horsepower examples when your plug in your data. This is the blank one... http://www.c4caraudio.com/tech...2.xls This one has the data from my car in it, VH45DE '94 Q45. If you just half the engine displacement to 137 cubic inches and 1/2 the horsepower desired on this one you could use it for your application. Just use two of the turbo's you select and double the horsepower calculation for the end result. Maybe I should make a new page for twin turbo calculation...hmm. http://www.c4caraudio.com/tech...l.xls For the MAF you have a couple options that come to mind. since you are using twin turbos you could use twin MAFs either blow through or draw through. I've heard of a few people that moved the MAF to the back and did draw through. I don't think I would personally do that. Many people also just use the MAF element and install it in a larger tube making their own larger MAF. The reading will be lower for a larger volume of air. You just have to retune for the change in the load/TP level. I haven't done this with mine yet but it should't be too difficult. The single larger MAF is the way I'd go. Here's a link to one article I found on this mod. http://autospeed.com/A_2631/xB....html
Modified by qsiguy at 1:16 PM 5/12/2008
npez
1993 Nissan 300ZX Turbo (soon 2B twin-turbo 450ZX) 2002 BMW M3 2008 Honda Odyssey Touring (Mama)
Houston TX
8-30-2007
| « Re: (qsiguy) | 12:36 PM 5/12/2008 |
| Quote, originally posted by qsiguy » | | I'm a believer in the rear mount turbo setup so you have my vote there. |
I love your setup. I've been reading about it a lot here on NICO and it was part of the inspiration (the other part is reality of trying to twin-turbo this motor in the Z32 engine bay ) of doing a rear twin-turbo configuration.
| Quote, originally posted by qsiguy » | | Here's a link to my excel spreadsheet for turbo selection, I used the information from the Garret web site tutorials to make it. For twin turbos you just use 1/2 the displacement and HP goal. Sheets 2 and 3 of the spreadsheet also have information on them as well. It gives you a total of 9 horsepower examples when your plug in your data. This is the blank one... http://www.c4caraudio.com/tech...2.xls This one has the data from my car in it, VH45DE '94 Q45. If you just half the engine displacement to 137 cubic inches and 1/2 the horsepower desired on this one you could use it for your application. Just use two of the turbo's you select and double the horsepower calculation for the end result. Maybe I should make a new page for twin turbo calculation...hmm. http://www.c4caraudio.com/tech...l.xls
This is a fantastic spreadsheet I recommend it to all! - I downloaded it a few days ago I just hadn't connected Shane with your screen name - I too went through the calculations at the Garrett website and your spreadsheet was a Godsend. As far as a TT section, you could do it, but the alternative (halfing the displacement) works just as well considering your audience (people that have a pretty good understanding to begin with) and the fact that your reader is now going down the path of treating the motor as two 2.25 liter motors. | Quote, originally posted by qsiguy » | | For the MAF you have a couple options that come to mind. since you are using twin turbos you could use twin MAFs either blow through or draw through. I've heard of a few people that moved the MAF to the back and did draw through. I don't think I would personally do that. Many people also just use the MAF element and install it in a larger tube making their own larger MAF. The reading will be lower for a larger volume of air. You just have to retune for the change in the load/TP level. I haven't done this with mine yet but it should't be too difficult. The single larger MAF is the way I'd go. Here's a link to one article I found on this mod. http://autospeed.com/A_2631/xB....html |
I think I will probably go the route of dual MAF (though the mod is pretty trick). Would you go for A) dual TT MAFs rewired (different connector), B) use stocker Q45 ones, or a variation of the mod above (frequently done on Z32 TTs) whereby you fab up a Y pipe with [2] 2.5 intake tubes merging to a single 90mm tube which would go to the VH throttle body; one part of the Y would house the Z32 MAF and the other would be a flow through? Thanks again for your feedback - I'll probably be "tapping" you for info when I get into phase 2. Do you believe the HP goal is attainable with what I'm looking at doing? It is in theory based on the spreadsheet I'm just not sure what else could go at this level (I had heard something about the oiling system not being up to snuff for really high HP) Best regards, Nick.
qsiguy
Phoenix AZ
3-20-2005
Are you running the compressor plumbing from both turbos into an intercooler then out via one larger tube into the throttle body, dual IC's then merge into one to the throttle body, or will you be using dual throttle bodies? If you are going single you could put one MAF between the IC and the throttle body. Of course it would have to be modified larger.I'm not exactly sure how the dual MAFs are installed/wired. I've heard of having a "dummy" MAF but if it's a dummy I'm not sure why it's even there. Seems like if you just put one MAF (any type TT or OEM VH) on one of the turbo compressor outlets so you were just measuring 1/2 the air flow, you could just tune for that. In theory that's about the same thing as putting the MAF in a larger tube. Someone correct me if I am way off base on this one. From what I've seen tuning mine, if you know the TP, whatever it is, you can tune for that. So as long as the flows remain pretty much equal between the two turbos you should be able to tune with one MAF(?).. [This is me thinking out loud.]
npez
Houston TX
8-30-2007
| « Re: (qsiguy) | 4:24 PM 5/12/2008 |
Hi Shane,I'm not planning on dual throttle bodies. I'm planning on a 2-in 1-out intercooler unless I have space issues running that big a pipe from the FMIC to the throttle body (don't want to hack up the car too much). Worse case scenario I'll run 2-in 2-out then a Y that will merge the flow into a 90mm pipe to the single Q throtle body. Going the latter route I could mount a Z MAF on one of the legs of the Y and a dummy one on the other (similar result to the MAF in a larger pipe). As far as the dumy MAF I'm under the impression that the doolz systems that are used on the Zs basically are done to split the air in half (and allow for even more airflow x2). Of course the Z has dual throttle bodies and is more analogous to having [2] 1.5L motors versus the Q. The dummy MAF sensor is used to allow for the same restrictions (read wire mesh in the MAF) as the real MAF on the other side. The fundamental principle for this system to work is that the unmetered air is equal to the metered airflow. So the doolz system will allow for more air while allowing the MAF on the one side to measure half the air (with proper tuning) and still max out at 500HP but being that's only half the airflow it would be 500HP x 2. The most straight-forward solution would be to get a MAF that can handle the higher HP, and plumb it before the throttle body but after the BOV as you've done but I read somewhere that you loose resolution with larger MAFs which may affect streetability at lower RPM. Not sure if you or anyone has heard anything to that effect. Thanks, Nick.
npez
Houston TX
8-30-2007
| « Re: (qsiguy) | 4:34 PM 5/12/2008 |
Shane,I also wanted to add, that I have all the factory IC and plumbing that I took off my car, so dual IC with a merge would be possible but I would then need to go air-to-air intercooling. Not sure how well this would work though..... versus the alternative. Nick.
T45
King Kong powered Z32
va beach va
6-9-2006
Looks like a solid build. One suggestion you mentioned was relocating the fuel lines which is what I have planned the next time the plenum is off. Hindsight is 20/20. lol I plan on just removing the hard lines from the engine and routing my flexible lines from the Z to the rails where they hook up to the damper and regulator.What are you planning for your P.S.?
npez
Houston TX
8-30-2007
| « Re: (T45) | 6:48 PM 5/12/2008 |
Hi T45,Thanks for the feedback. For the P/S I'm planning on using the stock Q pump (hopefully everything will clear - I'll know for sure when Craig comes down so we can weld the mounts). The plan is to take the Q high pressure hose from the pump to the rack and lengthen it by about 2-3 inches and add a fitting for the P/S pressure sensor. For the return line from the rack I'm going to use the factory hardline that crosses through the front of the car and used to return to the HICAS solenoid. I will lengthen the hose on the end of that line and go to a NA Z's reservoir (just picked one up on ebay). For the fill line I'm going to have a 1/2" line fabbed (same bends as the factory line) and siamezed (attached) to the existing return line so this will allow me to have all factory bracketry securing those lines. A side benefit is that this allows me to leave the P/S reservoir in the Z's factory location. I'm doing something similar with the A/C (gotta have A/C in Houston) - I may reuse the factory Q's suction side (directly from the evap core) but will have a new high side line made that will go from one side of the condenser to where the drier currently is and have a hose attached to the end of it with the Q fittings for the compressor. I found a place here locally that will do all the lines for a couple of hundred dollars, I'll see what they say when I bring them the stuff. My goal is to retain all the creature comforts while keeping everything stock looking (nothing seeming out of place except the motor) Thanks again for your feedback. Nick.
Modified by npez at 7:20 PM 5/12/2008
qsiguy
Phoenix AZ
3-20-2005
| « Re: (npez) | 7:19 PM 5/12/2008 |
| Quote, originally posted by npez » | | Shane, I also wanted to add, that I have all the factory IC and plumbing that I took off my car, so dual IC with a merge would be possible but I would then need to go air-to-air intercooling. Not sure how well this would work though..... versus the alternative. Nick. |
You really could do pretty well with the OEM IC's since the intake temps will be cooler already since you have rear mounted turbos. Are you planning any methanol or water injection? That would help as well. I just ordered an intercooler. I had planned to leave it out and just let the methanol injection handle it but I'm addicted and if I can get 20-30 or more hp by installing an intercooler then I'm sold. Also, for the time being I'm pretty much limited to about 8-9 psi max with these 370cc injectors and stock MAF so I want to get the most power I can from my 8 psi. Of course when I cool the intake charge down I may find I just max out the MAF and injectors sooner. Oh well, cross that bridge when I get there.
npez
Houston TX
8-30-2007
| « Re: (qsiguy) | 7:29 PM 5/12/2008 |
| Quote, originally posted by qsiguy » | You really could do pretty well with the OEM IC's since the intake temps will be cooler already since you have rear mounted turbos. Are you planning any methanol or water injection? |
I was looking at the snow system from Z1 Motorsports for the VG30DETT; I may consider that for the VH as well. The beauty about it is it's engineered for the Z so they provide a NA Z windshield washer tank that fits neatly on the RH side of the car and all the plumbing fits the Z. On the TT the windshield washer fluid is on the LH side back. Like you I'm thinking running cheap windhield washer fluid. I suppose I can get the generic kit and do it myself - I'll see what the price difference is. It's good to hear that you picked up an intercooler - that will help a bit. The methanol injection will help a lot! I know what you mean by addiction. It seems you tell someone you're putting 400+ to the wheels and the thrill is amazing - for about a month. Then you don't "feel" it anymore and want more. I look forward to hearing how the cooler air is working out - very curious on the MAF sensor.... Nick.
craigztoyz
90 300ZX VH45 95 J30 90 rx7 lots of cars older then me.
Austin TX
1-18-2008
| « Re: (npez) | 11:24 PM 5/12/2008 |
Nick, as much as we have talked, Nice to see pics of it. WOW. Nice car. Gonna be sick really soon. I;m finishing up a few projects, and after mine is all mounted up I can drive it up there.
qsiguy
Phoenix AZ
3-20-2005
| « Re: (npez) | 11:38 PM 5/12/2008 |
| Quote, originally posted by npez » | | ....It seems you tell someone you're putting 400+ to the wheels and the thrill is amazing - for about a month. Then you don't "feel" it anymore and want more.... Nick. |
I got a new appreciation for the speed of my car during a recent business trip while in my rental car...a Chevy Cobalt Kinda cool looking with the wing and all but you put your foot down and I was sure there was something keeping the pedal from going all the way down At that moment I said to myself, wow, my car is really fast! Can't wait to see your build get started. I really love watching builds materialize. Make sure you document it well and take lots of photos. Others like them and I have referenced my install photos many many times figuring out how to do something.
npez
Houston TX
8-30-2007
| « Re: (craigztoyz) | 11:42 PM 5/12/2008 |
Thanks Craig.and sweeeeet! I can't wait...... I got most of the garage picked up after the ceiling renovation for the lift - and all the "extra" parts I've taken out of the Z are finally in the attic versus the floor..... I'll post some pictures of the car in it's current state and then take some photos of the "sister" harness and labeling as I do the soldering work..... Thanks, Nick.
npez
Houston TX
8-30-2007
| « Re: (qsiguy) | 11:49 PM 5/12/2008 |
| Quote, originally posted by qsiguy » | I got a new appreciation for the speed of my car during a recent business trip while in my rental car...a Chevy Cobalt Kinda cool looking with the wing and all but you put your foot down and I was sure there was something keeping the pedal from going all the way down At that moment I said to myself, wow, my car is really fast! |
That's funny with the cobalt. When you think that you're probably putting down 3-4x the horsepower it all starts to make sense..... | Quote, originally posted by qsiguy » | Can't wait to see your build get started. I really love watching builds materialize. Make sure you document it well and take lots of photos. Others like them and I have referenced my install photos many many times figuring out how to do something. |
I'm pretty excited about it. I've already started taking pictures and will post the "current state" as soon as I download them off the camera and resize them. The car is a shell at the moment as far as the powertrain but when Craig comes down from Austin, I'll put the car on the lift and make sure I take photos from many different angles...Take care, Nick.
npez
Houston TX
8-30-2007
| « Current state photos of the Z | 12:34 AM 5/13/2008 |
Not much to report on yet. This is the starting point for the car. I rinsed the car off but its still pretty dirty . So far I've removed the following:-engine/trans/driveshaft -Midpipes (Random Technology High Flow Cats) and X pipe -EFI harness -HICAS engine bay hydraulic lines and HICAS solenoids -Radiator/AC Condenser/AC Drier -A/C Line from cross-member and nose of the car. -Bumper Cover & Bumper supports -All turbo plumbing, recirculating valves, intercoolers, etc. In the pictures you'll see some of the items I'm referencing in the thread such as the power steering return hard line on the LH frame rail as well as the HICAS hardlines that go from the LH engine bay to the back of the car. I'm going to be using these as oil feed/return lines with an electric oil pump for scavenging in the rear of the car. When Craig comes down for us to weld up the mounts and put the engine in, I'll take lots of pictures for an update. Nick. The Z Disassembled
 RH Side of Engine Bay - HICAS Solenoid + Lines Removed as well as EFI Harnes
 LH Side of Engine Bay - You can see the P/S Return Line on the frame Rail. I'm going to have a 1/2" line made and siamezed to this one for the feed line to the pump.
 A closeup of the HICAS Lines. These will be used as oil feed/return lines as the twin-turbo setup will be rear-mounted.
 A couple of pictures of the 1994 VH45DE motor that will be going in
 That's all I've got until I take pictures of the harness work. Nick.
qsiguy
Phoenix AZ
3-20-2005
Holy cow, I didn't realize you were already that far. Awesome! And another holy cow, that's the garage at your house!!!! I want a lift, man I am really really jealous. You rock.
T45
va beach va
6-9-2006
What a terrible father. Your kid has a bone stock pink corvette while daddy is busy hopping up his Z. Show the kid some love and put in a couple more batteries in series will ya?  Some suggestions if I may. You have an excellent looking engine. If it were me I would leave it alone until the turbo build. I wouldn't pull anything off of it at all, just the exhaust mani's and drop it in. You'll also have to modify the coolant neck where the fill cap is on the engine. It sticks up too far and interferes with the Z hood a lot more than the plenum. Also, what are your plans for your plumbing to the intercooler(s) from the turbo's? Once the VH is in there is very very little room to route plumbing around it. Just curious. I'll pop up with random memories and suggestions as your build progresses. It just comes to me in flashes, must be menopause...
npez
Houston TX
8-30-2007
| « Re: (qsiguy) | 8:35 AM 5/13/2008 |
| Quote, originally posted by qsiguy » | | Holy cow, I didn't realize you were already that far. Awesome! And another holy cow, that's the garage at your house!!!! I want a lift, man I am really really jealous. You rock. |
Shane, Yeah I started about 6 months ago when I took the Z motor out de-torqued the heads and then disassembled the rest of the motor to make an assessment of what kind of damage I had. The bulge around the flange and the tear in the metal of the oil pan weren't good signs. When I finally assessed I found out the #6 rod had snapped on the big end and went flying down, broke the girddle and then all that went flying around hitting the crank and tearing everything up. About 3 months ago I started researching different motor options and decided on the VH, picked up the parts and began work on this project. The hydraulic lift was a present from my wife. It makes it much easier to work on the car. Thanks. Nick.
npez
Houston TX
8-30-2007
| « Re: (T45) | 8:46 AM 5/13/2008 |
| Quote, originally posted by T45 » | What a terrible father. Your kid has a bone stock pink corvette while daddy is busy hopping up his Z. Show the kid some love and put in a couple more batteries in series will ya?  |
I suck don't I? Believe it or not the little mustang is pretty fast to begin with but I had looked into some motors that are a little higher voltage and faster. I guess she'll have to wait until she's 6 or 7 for that! Confusius said "too much power bad for little 4 year old girls" | Quote, originally posted by T45 » | | Some suggestions if I may. You have an excellent looking engine. If it were me I would leave it alone until the turbo build. I wouldn't pull anything off of it at all, just the exhaust mani's and drop it in. You'll also have to modify the coolant neck where the fill cap is on the engine. It sticks up too far and interferes with the Z hood a lot more than the plenum. |
Thanks for the compliment I will probably be coating some of the parts later (when it's in the machine shop) to make it pretty. What type of modification is done (i.e. do people just hack a part off)? There's the ECT and Engine Temp for the temp gauge on this pipe. Please advise if you remember off the top of your head - or if you have a picture that would be great too....| Quote, originally posted by T45 » | | Also, what are your plans for your plumbing to the intercooler(s) from the turbo's? Once the VH is in there is very very little room to route plumbing around it. Just curious. |
I was thinking along side the frame rails but I won't know exactly how until I see the motor in there and I start looking around..... It also depends if I'm going to use the factory ICs as the pipes would then need to go to the nose of the car. Once there the plumbing routing should become a little more straight-forward.Thanks again for all your feedback..... Nick.
npez
Houston TX
8-30-2007
| « Injector Sizing and some thoughts | 7:16 PM 5/13/2008 |
So I've been playing with injector sizing to try to figure out if the 555cc injectors I have will be too small. To my surprise they can work under this scenario:Goal 600HP (Crank) approx 500RWHP Brake Specific Fuel Consumption (BSFC): .625 (turbocharged) Injector Duty Cycle: 85% (a little higher than the typical 80%) Fuel Pressure: 47PSI (a little higher than stock) So if I increase the fuel pressure and don't beat the snot out of the car the 555cc injectors should work. Anyone have any thoughts on this? If I keep the fuel pressure at stock the injectors would be marginally too small. Is the best bet to go to 720cc NISMOs to get more upside or stick with what I have? My understanding is that going way big may introduce other issues like low RPM atomization, etc. so if anyone has any experience/constructuve criticism on this I would appreciate your feedback. Also I've been tinkering with the idea of braking Phase 2 into a 2A and 2B to help expedite things and have tangible results faster. 2A would incorporate the turbo's at 7-8PSI (maybe more) with stock internals, the TT factory ICs, the 555cc injectors, TT oil cooler integration, water/alcohol injection, and ECU tuning. 2B would go further with having the engine rebuilt low compression, stronger internals, turning up the boost, MAF work, and additional ECU tuning. Doing it this way divides the cost to maybe $2-3K USD for 2A as I have most of the stuff already, and another $3-4K USD for phase 2B. The benefit is that for relatively small dollars I can have a car that's pretty darn quick after 2A. Also I don't have to explain $7K all at once to my wife . Judging by Shane's video and my previous setup (about 380RWHP) I think the bulk of my problem will be traction anyway (which can be addressed after 2A). Does this sound reasonable or will I have challenges finding a turbo that will be flexible enough (lag, flow, etc.) at 7-8psig as well as 16psig in phase 2B (I obviously don't want to buy turbos twice). I know the GT25s that the VG30DETT came with had an operating range of 9psig stock and could go to 18psig after which they were just blowing hot air. I know the GT25's would be way small; I'm using that as an example. A side benefit will be that I can then set my Greddy Profec B later to have a low setting of 7-8psig (for when my wife drives the car) and 15-16psig (for hauling butt) Thanks, Nick.
T45
va beach va
6-9-2006
On my coolant neck I just cut it off to where I could plumb a rubber hose to it. I'll post pics when I get a chance.Along the frame rails... well there is about 0 room along the frame rails after the engine and mani's are in. I believe the best option is to do a TT setup using forward facing mani's, ditching the a/c and p/s pumps, and using similar routing to the stock Z intake piping. There really isn't any room...at all. lol I'll keep looking at my build and see what I can come up with.
npez
Houston TX
8-30-2007
| « Re: (T45) | 10:00 PM 5/13/2008 |
T45,Thanks for the feedback. | Quote, originally posted by T45 » | | On my coolant neck I just cut it off to where I could plumb a rubber hose to it. I'll post pics when I get a chance. |
That will be great - it sure will make it easier - did you have to weld a bead on the end so you could clamp the hose, or does the hose hold pretty well with just the clamp on the pipe? | Quote, originally posted by T45 » | | Along the frame rails... well there is about 0 room along the frame rails after the engine and mani's are in. I believe the best option is to do a TT setup using forward facing mani's, ditching the a/c and p/s pumps, and using similar routing to the stock Z intake piping. There really isn't any room...at all. lol |
Man that's a buzz kill. If there isn't any room removing a/c and p/s wont be an option - I need to retain the creature comforts that's one of the project givens. When you mentioned the lack of room I started staring at the car this evening and was trying to think a little out of the box. This idea may sound crazy but bear with me. What would prevent me from running 2-1/2" plumbing through the fenderwell? If you look underneath that's where the body harnesses are run. There's actually a channel of sorts under there. So with some heatshielding/wrap around the electrical harnesses, there may be enough room to tuck the plumbing underneath. This would make the plumbing end up covered by the underfender splash shields. The front of the pipe would also end up right where the factory intercoolers are. I will have to lift the car up and pull the wheels off to confirm, but it may be plausible, though unorthodox somewhat. | Quote, originally posted by T45 » | | I'll keep looking at my build and see what I can come up with. |
That will be great - keep in mind when you're looking that I don't want to sacrifice the creature comforts.....Thanks again for your feedback and I'll let you know (maybe take some pics as well) once I have the car up in the air.... Thanks, Nick.
npez
Houston TX
8-30-2007
| « Turbo Plumbing through the Fenderwell? | 12:53 AM 5/14/2008 |
ok - so I thought about it some more and being it's 1:30AM here in Houston and the family is sleeping, I decided to take it apart and take a peek and pics.The pics are of the RH fender (wing for our international readers) - Based on what I see I seriously think this may be a do-able option if there simply is no other logical way to route through the engine bay. I am aware that the LH side has the vacuum tank for the PRVR but that's going away anyway. The only other thing that *may* get in the way is the overflow tank, but I think we still have about 3 inches to route the pipe. The 9 o clock position may be a little tight as well but I didn't take a good picture of it. Fabbing the bend on the aluminum pipe may cost a little bit but to me at least it would be worth it to keep a/c and p/s. A benefit with this routing is that the pipe while a little longer then a straight shot through the engine will be away from engine heat and therefore a little cooler. So here are the pics. The channel I mentioned in an earlier post between the fender and inner fender support. This is at the 12 o clock position
 Front of the fender around 4 o clock position - the black thing in the picture is just a piece of plastic that is trimmable if need be
 12 o clock again with measurement to the underfender splashield mounting tab
 10 o clock with measurement to the splashield mounting tab
 Crazy idea or worth exploring further? Comments/feedback as always is appreciated. Thanks, Nick.
T45
va beach va
6-9-2006
As for the coolant neck it has a textured surface and I think just a clamp will suffice, but if you're got the resources it wouldn't be a bad idea.The fenderwell is the other option I researched. It would work perfectly for the front half of the car. Once you're under the car it gets tight again. I brainstormed of running a single rear mount, hooking the mani's together near the trans and using one of the stock exhaust pipes to feed and one for return, kinda like your hicas oil feed idea. I didn't break out a tape measure or anything, just eyeballed. That's so far off in the future it's not worth getting my hopes up for. I can barely afford to get it on the road as it is, having to shadetree a lot just so I can drive it and work out some bugs.
npez
Houston TX
8-30-2007
| « Re: (T45) | 7:54 AM 5/14/2008 |
T45,Thanks a bunch for the feedback. | Quote, originally posted by T45 » | | As for the coolant neck it has a textured surface and I think just a clamp will suffice, but if you're got the resources it wouldn't be a bad idea. |
I'll call a friend of mine that TIG welds and see if he can do a bead otherwise I'll run it as is like you did. | Quote, originally posted by T45 » | The fenderwell is the other option I researched. It would work perfectly for the front half of the car. Once you're under the car it gets tight again. I brainstormed of running a single rear mount, hooking the mani's together near the trans and using one of the stock exhaust pipes to feed and one for return, kinda like your hicas oil feed idea.
Since I' have the car up in the air, I may investigate this a little more while I wait for Craig to wrap up and come down. The exhaust mani with single turbo setup is trully out of the box thinking - very impressed. I'll keep hammering at this to see where it takes me. I'll post some more pics from underneath if I see something workable. Once I get it all figured out, and I will as I'm pretty tenacious with these types of issues, and we have a workable solution, I'll post it so you can reference it later when you're ready and if you choose to go down this path.....Thanks, Nick.
craigztoyz
Austin TX
1-18-2008
| « Re: (npez) | 11:29 AM 5/14/2008 |
| Quote, originally posted by npez » | Shane, Yeah I started about 6 months ago when I took the Z motor out de-torqued the heads and then disassembled the rest of the motor to make an assessment of what kind of damage I had. The bulge around the flange and the tear in the metal of the oil pan weren't good signs. When I finally assessed I found out the #6 rod had snapped on the big end and went flying down, broke the girddle and then all that went flying around hitting the crank and tearing everything up. About 3 months ago I started researching different motor options and decided on the VH, picked up the parts and began work on this project. The hydraulic lift was a present from my wife. It makes it much easier to work on the car. Thanks. Nick. |
Yea, the othr day on the phone I realize that Nick has a LIFT IN HIS GARAGE!!!!!!! 21 years building cars, and i don't even have a lift. We need more wives like her.
craigztoyz
Austin TX
1-18-2008
| « Re: (npez) | 11:51 AM 5/14/2008 |
| Quote, originally posted by npez » | | T45, Thanks a bunch for the feedback. I'll call a friend of mine that TIG welds and see if he can do a bead otherwise I'll run it as is like you did. Since I' have the car up in the air, I may investigate this a little more while I wait for Craig to wrap up and come down. The exhaust mani with single turbo setup is trully out of the box thinking - very impressed. I'll keep hammering at this to see where it takes me. I'll post some more pics from underneath if I see something workable. Once I get it all figured out, and I will as I'm pretty tenacious with these types of issues, and we have a workable solution, I'll post it so you can reference it later when you're ready and if you choose to go down this path.....
Thanks, Nick. |
Nick, I just cut the neck leaving enough to clamp hose onto it without interfering with the outlet side right beside it. Look at some of the pics I sent you. There is NO engine bay room for plumbing. But trust me I am looking into it too. Not to worry, one step at a time. engine is sitting in bay right now, all wired in, testing everything, and then as soon as i get these darn bolts to hold flywheel to crank and p/p, then should be good to go. trying to tye up work here, to gt out asap. Pan fits Great!, mani's, well I beat the crap out of them, and they need more. Resting on mani's and frame, and have a 1/8 between pan/ rack. Getting there. here are a few pics.....you should be able to see my waterneck.
and here is one for all the haters who thought the pan would sit too low or in the way.
npez
Houston TX
8-30-2007
| « Re: (craigztoyz) | 1:11 PM 5/14/2008 |
Craig,Great update! your car looks great! Everything seems to be coming together very nicely. I'm going to lift the car all the way up and start peeking underneath to see the different ways plumbing could be run. More academic at this point then actually doing it, but I want to see what all the different options are. I'll let you know what else I come up with. Great pic of the filler neck as well - I'll cut mine there too  Thanks, Nick.
npez
Houston TX
8-30-2007
| « Re: (T45) | 2:47 PM 5/14/2008 |
Man, I see what you mean. With the car up in the air completely it is really tight under there. Tighter than I remember. One option (maybe) is to run aluminum piping that is rectangular (I've found some that is 2"x4") and run it along the frame rails on the outside, but we still run into the floorpan droping downwards toward the rear sub-frame.The more and more I think about it, your idea of a single turbo may be way more straight-forward than twins. But I'll keep looking to see if I can find any other options. Thanks, Nick.
Mettler
VH Moderator
Hamilton
1-15-2006
Haha craigztoyz you should host your pics on photobucket instead of picvault, photobucket will allow you to easily rotate your pics to be the right way around npez, I'm jealous of your car lift >_< It's exactly what I need right now! Have you thought about building forward facing manifolds, but having them squeeze out and up past cylinders 1 & 2 on each side at rocker cover level, then forwards before flanging for the turbos? That'd let you miss the P/S and A/C pumps, and mount the turbos behind the headlights in a similar fashion to canadiandrifter240sx's setup. I reckon that'd work, judging vaguely by the pics craigztoyz posted of his engine mounted in place.
Nissan VH V8 > your preferred engine.
npez
Houston TX
8-30-2007
| « Re: (Mettler) | 3:46 PM 5/14/2008 |
| Quote, originally posted by Mettler » | | npez, I'm jealous of your car lift >_< It's exactly what I need right now! |
It's funny you mention that, because I always wanted one - got tired of rolling around on the floor and at 39 now it was really wiping me out. Getting the lift though was the easy part. It took me about 3 weeks to remove a 14 foot section of ceiling from the garage to get 13 feet height across the 14 foot span, then I had to brace the roof rafters (made A-frames on top and blocked them on the structural walls) and then had to reframe the attic space on both sides of the double-bay to seal the garage again (it's air conditioned). I brought a sheetrock crew to sheetrock the vaulted ceilings and I then added [4] 2 foot x 4 foot recessed fluorescent light fixtures (like I'm performing surgery ). I then had to re-wire my entire house to a new electrical sub-panel as all the house wiring (detached garage) was running down the middle of the garage above the ceiling joists in the attic that I removed and weren't long enough to just move out of the way. I was cussin up a storm having to do all this, but in the end it all was worth it. Anyway back to our discussion.| Quote, originally posted by Mettler » | | Have you thought about building forward facing manifolds, but having them squeeze out and up past cylinders 1 & 2 on each side at rocker cover level, then forwards before flanging for the turbos? That'd let you miss the P/S and A/C pumps, and mount the turbos behind the headlights in a similar fashion to canadiandrifter240sx's setup. I reckon that'd work, judging vaguely by the pics craigztoyz posted of his engine mounted in place. |
I had thought about it but I didn't think I could squeeze the turbos behind the headlights - now you have me thinking. Another option would be to take the front facing pipe and routing it to the nose (under the front panel where the airbox used to be) and mounting 2 turbos in there.I asked Craig if he can send me some eye level photos of the LH and RH side manifolds in his engine bay to see how much room is actually there. I am really wanting a twin-turbo setup so we'll have to see if the turbo will fit behind the headlights or the alternative of running it under the nose. There has to be room somewhere to fit the twins in there. Thanks for your feedback and suggestions, Nick.
npez
Houston TX
8-30-2007
| « Re: (Mettler) | 3:50 PM 5/14/2008 |
You are the photoshop master - you rock I see what you're saying though. In my last reply I thought the turbo would be more forward than that. I will have to see what would need to happen with the main electrical box on the LH side though. I think a turbo that close even with heatshields will melt that thing.... I'll go look...... Thanks, Nick.
npez
Houston TX
8-30-2007
| « Re: (Mettler) | 5:05 PM 5/14/2008 |
Mettler,I pulled the LH manifold off the motor and tried something funky for kicks. I flipped the manifold over (clocked it 180 degrees) and other than some interference from the downpipe and the first tube with the head around cylinder 1(? forward most cylinder on the LH side) - it fits! I'm thinking that if the downpipe was cut including the O2 bong, etc., possibly the first tube as well, and cleaned up it may set the tube in a position where the flange can be mounted on. This would minimize the amount of work needed on the manifold to just minor welding and would get us to the endpoint you suggested in your illustration. Doing it this way also opens up enough space on the side of the motor (as the individual header pipes are now angled up) to run the exhaust from the wastegate and tie it into the exhaust system. Have you heard of anyone flipping the manifold over like this? Please advise. Thanks, Nick.
Mettler
VH Moderator
Hamilton
1-15-2006
Wow what a heck of a lot of work to fit your hoist!! >_<That's interesting that you can flip the manifold just like that, and it goes a long way to illustrating what's possible. Personally, I'd be inclined to fabricate new manifolds from scratch, as I'm not sure how durable the stock header manifolds would be if modified for twinturbo application... and they aren't all that nice quality inside either. Though they are fairly thick walled I guess... but how prone would they be to cracking etc? Anyway, that's just speculation... it shows you that such a manifold style would fit... you're probably not the first to think of that Would be keen to read other people's opinions about recycling the stock manifolds... it's a pretty good idea as long as they're made well enough for the purpose. And it should leave room for a 3" exhaust system on either side that as you said, you could plumb the external wastegate back into. Another thing to consider would be that your turbos won't actually need to be all that huge. You only need an average sized (good quality) turbo to get 400HP out of an SR20DET... and considering the VH head design flows better, two medium sized turbos like GT3076Rs would undoubtedly be sufficient to achieve 800HP or so (flywheel), and could be small enough not to interfere with anything when mounted as discussed. I've always felt this is how you'd ideally want to mount the turbos in a V8 twinturbo setup to keep the plumbing as short as you can, because while rear mounting is possible, you'd need a whole lot more pipe... and then your system is also at greater risk of damage from road hazards under the car. I dunno about you, but I've smashed bits off cars before from hitting possums and rabbits on the road... lol
tmorgan4
2000 Pathfinder
Fort Collins Co
12-24-2006
| « Re: Project Road Terror Z (npez) | 6:08 PM 5/14/2008 |
Have you looked at Tecni's manifold design? Obviously a log style manifold isn't IDEAL but I still like the way his are done. http://forums.nicoclub.com/zer...age=3
npez
Houston TX
8-30-2007
| « Re: (Mettler) | 6:22 PM 5/14/2008 |
| Quote, originally posted by Mettler » | | Wow what a heck of a lot of work to fit your hoist!! >_< |
Unimaginable! but now I can walk under the car standing up  | Quote, originally posted by Mettler » | That's interesting that you can flip the manifold just like that, and it goes a long way to illustrating what's possible. Personally, I'd be inclined to fabricate new manifolds from scratch, as I'm not sure how durable the stock header manifolds would be if modified for twinturbo application... and they aren't all that nice quality inside either. Though they are fairly thick walled I guess... but how prone would they be to cracking etc?Anyway, that's just speculation... it shows you that such a manifold style would fit... you're probably not the first to think of that Would be keen to read other people's opinions about recycling the stock manifolds... it's a pretty good idea as long as they're made well enough for the purpose. And it should leave room for a 3" exhaust system on either side that as you said, you could plumb the external wastegate back into.
I'd be interested to hear what others have to say as well. I think if gussetted properly they'll be pretty strong - the stock manis don't look too bad from what I've seen - look like stainless steel oval tubes and the flange is actually angled for better flow. I know a guy that TIGs very well so I can ask him about strength, etc. and see what his thoughts are as well and I can keep everything stainless steel. | Quote, originally posted by Mettler » | Another thing to consider would be that your turbos won't actually need to be all that huge. You only need an average sized (good quality) turbo to get 400HP out of an SR20DET... and considering the VH head design flows better, two medium sized turbos like GT3076Rs would undoubtedly be sufficient to achieve 800HP or so (flywheel), and could be small enough not to interfere with anything when mounted as discussed.I've always felt this is how you'd ideally want to mount the turbos in a V8 twinturbo setup to keep the plumbing as short as you can, because while rear mounting is possible, you'd need a whole lot more pipe... and then your system is also at greater risk of damage from road hazards under the car. I dunno about you, but I've smashed bits off cars before from hitting possums and rabbits on the road... lol |
That's the turbo I was looking at over at the garrett website I'll have to get some dimensions and see how everything can fit. I liked the rear mount as the intercooling effect on the charge pipes is a good thing as well as the turbos being away from all the heat. But looking at what would be involved is a different story.... Front mount may be the only feasible way to go but this way I'll have oil and water to go ball bearing on the turbos..... I'm also going to call a bud that has a junkyard (he has a Q45 motor with a knock) and get the manifolds from that one (I believe 91-94 should be the same) - this way I can hack one set up as turbo manifolds while having my originals to complete phase 1.This is getting more interesting by the day..... Thanks, Nick.
npez
Houston TX
8-30-2007
| « Re: Project Road Terror Z (tmorgan4) | 6:33 PM 5/14/2008 |
I did, and it is definitely a viable option. I wanted to see if the stock manis can be easily adapted to eliminate much of the work of making custom manis from scratch, but if the tubing isn't thick enough or for any reason it's deemed that they aren't strong enough to be turbo manis then I guess I'll go down the route of having new ones fabbed. Also I think he's putting his in a G35 if I recall correctly which is a little wider that the Z32 engine bay. This may give him just enough additional room to make it all work.....Thanks for your input. Nick.
T45
va beach va
6-9-2006
We all know TT can be done on a Z. It's just that there are very very little details on how he did it, and I get the feeling he's not the kind of guy to share. Who knows how much work he did or how many mods he made to the frame, accessories he ditched, etc.I'm in the same boat as you though, I want to keep ps and a/c, make a nice sports car with great touring assets as well. What fun is a car that has 5 more hp, 15 less lbs of weight and no a/c?
tmorgan4
2000 Pathfinder
Fort Collins Co
12-24-2006
| « Re: Project Road Terror Z (npez) | 4:13 AM 5/15/2008 |
It's cool to see how much attention this car is getting. Even though you'll be hacking up the manifolds it might be easier to start with a set off a JDM imported engine since they don't have the bulky pre-cats all the US engines do. Who completed a TT VH45 Z?
konatown
94 Q45t, 2010 Genesis Coupe
Evansville IN
8-22-2006
| « Re: Project Road Terror Z (tmorgan4) | 6:04 AM 5/15/2008 |
Slim (450ZXTT username on here) is the only one I know of to complete a TT Z32. A couple of others in the works.EDIT: I take that back, Perana said he had one. He's across the big puddle and gets JDM spec parts but still had one running.
| First 1 2 3 4 5 6 7 8 9 > Last |
