CEO
03 G35C s/c, 93 S13 Vert KA-T, 09 Cube, 72 240Z RB25, 63 NL320, 67 WRL411, 67.5 SPL311, 05 Frontier
Phx, AZ
4-29-2002
Nick, that's simply amazing!!!!You get my vote for n00b of the year... Glad to have you aboard!!!
Project G35 Coupe For SaleTEAM NICO: 137,000 Nissan enthusiasts strong.
NICOclub on Facebook AZhitman on MySpace Love it here? Add a link to NICOclub to your site!
craigztoyz
90 300ZX VH45 95 J30 90 rx7 lots of cars older then me.
Austin TX
1-18-2008
| « Re: VH45DE to Z32 Complete Wiring Integration Document (npez) | 6:09 PM 5/7/2008 |
Thanx Nick. I went over it earlier, and looks all correct. I second the Noob of the year award. Trust me guys, we have been chatting for a few weeks about this, he has a lot of time in the wiring. He did an amazing job. Soon there will be 2 450ZX's within a hundred or so miles. i fortell awsome videos in the future. Again, Thanx nick.
craigztoyz
Austin TX
1-18-2008
| « Re: VH45DE to Z32 Complete Wiring Integration Document | 7:28 PM 5/7/2008 |
Nick, Oh yeah, I like the disclaimer you threw in, and gotta say the how to read this, sure makes it easier to read. Thanx again for all the leg work.
T45
King Kong powered Z32
va beach va
6-9-2006
Awesome work! There are a few mental notes I will add and these are all IIRC.In the fsm's it lists 2 wires for the fpcu on the Z. My z only had 1. 90 na 2+2 Don't remember the color. There are fan relay outputs from the Q ecu listed in the fsm. My 92 ecu did not have these. I believe infiniti added this feature to 94+. The early Q's have a thermoswitch in the radiators for fan activation.
npez
1993 Nissan 300ZX Turbo (soon 2B twin-turbo 450ZX) 2002 BMW M3 2008 Honda Odyssey Touring (Mama)
Houston TX
8-30-2007
| « Re: VH45DE to Z32 Complete Wiring Integration Document (npez) | 8:39 PM 5/7/2008 |
Thank you everyone for your kind words. Craig: Yeah I put the extra narrative at the top and notes, etc. on the bottom before posting the document as you and I have talked about this but it would be difficult for someone reading it for the first time. I fixed the typo on line C that you sent me (long nights) and will be posting the update v2.1 shortly. As for the disclaimer I had to put it in there because while the document makes it easier it's not meant to be a "how to re-wire your car for dummies" - like they say if it was easy everyone would be doing it! T45: Thank you for the feedback. I had added a bit about the fuel pump on the normaly aspirated Zs but it's buried at the bottom under "notes" (maybe I'll bring it to the top) - I don't believe they used variable fuel pressure so they aren't equipped with that feature (it's actually shown as a whole different setup on the 11x17 wiring diagram supplement that I have). If I'm misunderstanding you let me know and I can update accordingly. As far as the Q45 is there anyway you can elaborate on the thermoswitch (wire color - basic diagram if possible and PM it to me) and I can incorporate this new information into the document (Giving you credit of course - I'm going to add a credits section to the doc). Once again thanks to everyone. Nick.
T45
va beach va
6-9-2006
The thermo-switch is located in a port on the Q radiator. It is a 2 stage switch with the first stage closing or making contact at 190* F. The second stage closes well above 200. I'm not sure of the exact temp but it doesn't matter since most will want fans on at 190 and above. There are 3 wires, IIRC they are blue, green and black. Black runs to ground and I think the blue was the 190 wire. I could be wrong, it's all from memory. To find out I simply put the switch on the stove in a pot of water with a thermometer. At 190 the black made contact with the other wire, blue. I think. lol It's all taped up and a real ***** to get to for a visual. While I am typing this (sitting in my Z in the garage) I just hooked up consult. The plug by the ECU that runs to the Z contains the consult wires. I'm not sure if you have them yet but here they are. They are as follows. Q ecu harness to Z plug 21-brown/yellow to blue 22-yellow to white 31-brown/white to orange I haven't tested yet, need a serial-usb for my laptop but this should be correct. I'll keep everyone posted.
npez
Houston TX
8-30-2007
| « Re: (T45) | 10:55 AM 5/18/2008 |
Thank you for the information. I'll update the spreadsheet when I get back home and post the information.....Thanks Again, Nick.
T45
va beach va
6-9-2006
The consult wires are correct. It seems to be working great.
qsiguy
1994 Infiniti Q45 Turbo
Phoenix AZ
3-20-2005
Awesome document Nick. Regarding the thermo switch/fan issue. This would only be relevant if you plan to use the '94 16 bit ECU in your build. If you plan to use the 8 bit ECU from a pre '94 model which is easier to rechip and tune BTW, there wouldn't be wiring for that fan output. Even if you are using a '94-95 motor you could use the '93 ECU. The rechipped ECU in my '94 Q45 is from a '93.
npez
Houston TX
8-30-2007
| « Re: (qsiguy) | 12:00 PM 5/19/2008 |
| Quote, originally posted by qsiguy » | | Awesome document Nick. Regarding the thermo switch/fan issue. This would only be relevant if you plan to use the '94 16 bit ECU in your build. If you plan to use the 8 bit ECU from a pre '94 model which is easier to rechip and tune BTW, there wouldn't be wiring for that fan output. Even if you are using a '94-95 motor you could use the '93 ECU. The rechipped ECU in my '94 Q45 is from a '93. |
Shane,Thanks Shane. and thank you for the additional info. Let me ask you a quick (multi-part )question. On the ECM swap to pre-94, is it a plug and play affair? For example are the 94-95 EFI harnesses pinout compatible on the pre-94 ECMs? Are the 94-95 sensors compatible with what the pre-94 ECM is expecting? Are there any benefits to staying 16bit versus going to 8bit? Since you've already done it I thought you probably have gone through the rationalization of all of this. I've got a 94 motor/95 harness and both 94 and 95 ECMs. I can go over to my friend with the junkyard and swap one of the ECMs out for a 91 or 92 that he has. Please advise. Thanks, Nick.
SuperHatch
07 Tundra, VH Powered S14, VH Powered 92 Slicktop Z32, 92 Q45 Beater
Manahawkin NJ
11-17-2006
| « Re: (npez) | 12:52 PM 5/19/2008 |
| Quote, originally posted by npez » | Shane,Thanks Shane. and thank you for the additional info. Let me ask you a quick (multi-part )question. On the ECM swap to pre-94, is it a plug and play affair? For example are the 94-95 EFI harnesses pinout compatible on the pre-94 ECMs? Are the 94-95 sensors compatible with what the pre-94 ECM is expecting? Are there any benefits to staying 16bit versus going to 8bit? Since you've already done it I thought you probably have gone through the rationalization of all of this. I've got a 94 motor/95 harness and both 94 and 95 ECMs. I can go over to my friend with the junkyard and swap one of the ECMs out for a 91 or 92 that he has. Please advise. Thanks, Nick. |
Nick, The harness pinouts are the same, it is a plug-n-play affair.
- Stephen http://www.godspeed-racing.com
qsiguy
Phoenix AZ
3-20-2005
Copy that...No modifications necessary. Only difference that anyone can find is the cooling fan output. Both the 8 bit and 16 bit ECU's are tunable but in my opinion the 8 bit is easier. The main EPROM chip is a standard 28 pin chip. Same chips most tuners use fits right in. There are also emulators that will plug right in for real time tuning. I'm not sure how it would work for your application but in a otherwise stock Q we try and find an ECU from a car that had the same options like TCS. I know you can turn off a "TCS Flag" within the ECU so maybe it won't matter in your application
npez
Houston TX
8-30-2007
| « Re: (qsiguy) (superhatch) | 11:41 PM 5/19/2008 |
Thanks Guys - I really do appreciate the input - it's good to know that the ECMs are plug and play. Let me ask you another question. On the 94 electrical diagrams IIRC it shows a radiator fan as well as the A/C condenser fan. Is the A/C condenser fan functionallity there on the pre-94 (I don't have a pre-94 electrical diagram) or is it part of the thermo-switch you mentioned? I would assume it had an electric condenser fan but I haven't seen a complete car  Also Shane, Is there a portfolio of software/hardware tools you use that you would recommend as far as the tuning aspect of this? I'm somewhat of a noob when it comes to engine tuning though I have a general familiarity conceptually with fuel maps, timing maps, etc. and took some computer engineering classes during my undergrad work (this was ages ago though - maybe it'll come back and come in handy ). Please advise and thanks a bunch again for your help guys.... Nick.
qsiguy
Phoenix AZ
3-20-2005
A/C condenser fan still works fine. It turns on with the A/C and I'm pretty certain I've noticed it turn on when the motor was hot and the a/c was off. Either way I've never had any overheating issues with the '93 ECU.Components I use for tuning: 1)Tunerpro for editing the bin. 2)Burn1 hardware for burning the EPROMS. A Moates product. Flash n Burn software used for the burner. 3) ECUTalk I like for datalogs 4) Nissan Data Scan for map trace and some data logs. Also good for pulling your existing bin from an ECU. 5) Moates Ostrich 2. Don't have but I want it it is an EPROM emulator that takes place of the EPROM and allows tuning without swapping chips all the time. When used with EmUtility (free) it can allow for real time tuning. As soon as you save a bin file change EmUtility (available from the Tunerpro people) will send the new file to the Ostrich (or other emulator) even while the motor is running. 6) Nistune is also very cool but a little spendy. Allows real time tuning and map trace. These features can be done with the options above. I haven't used but it looks very cool. 7) And of course you will need a consult cable. Available from a few sources. BlaZt has one. I got mine from a NICO member, name is Jaime, can't remember his username but I'm sure I can find it. I think he also sells them on ebay. Think I paid about $70-80 IIRC. 8) Laptop 9) Wideband O2. I use the Zeitronics Zt2, I'm happy with it. 10) The chips/sockets are widely available. Moates, who sells the Burn1 and Ostrich, sells several types of sockets and chips. I like the 27SF512 which I believe is a very commonly used chip. You can write/erase/rewrite on them over and over again. I have a few of them but have been reusing the same two for dozens of tunes. While one is installed I'll make the desired changes, burn to a chip, open the ECU swap chips and do it again. This is why the Ostrich or other emulator would be awesome. Would save a ton of time.
npez
Houston TX
8-30-2007
| « Re: (qsiguy) | 9:35 AM 5/20/2008 |
| Quote, originally posted by qsiguy » | | A/C condenser fan still works fine. It turns on with the A/C and I'm pretty certain I've noticed it turn on when the motor was hot and the a/c was off. Either way I've never had any overheating issues with the '93 ECU. |
Shane,Thanks a bunch for all the info - I'll start looking all the stuff up as far as the engine management. Most likely I'll want to go the rom emulator route for dynamic tuning On the termo-switch is this what it looks like?
 If so I guess I will need to tap into a coolant line, add a fitting and mount it (I'm using a Howe radiator which I don't believe has a port for it)? I think the wires complete the coil circuit on the relay so I should be able to recycle my rad/sub relays. If T45's (Thanks for the info again) information is accurate then: - Black is ground - Blue is the ground side of the Low Speed relay coil - Green is the ground side of the High Speed relay coil The rest of the relay pins remain the same on the Z. Basically instead of the ECM providing ground this thermo-switch is doing the job on pre-94. If you see yours working differently than this, please let me know. Thanks, Nick.
T45
va beach va
6-9-2006
Das it. I plumbed mine into my drain port on the Z rad with an adapter but since I'm swapping radiators soon that's not going to work anymore. I'm not sure what I'm going to use but I think i'm going to use one of the adapter that goes into the upper rad hose and has a 1/4 npt for a t-switch. Either that or just put in a switch.
npez
Houston TX
8-30-2007
| « Re: (T45) | 12:14 AM 5/21/2008 |
| Quote, originally posted by T45 » | | Das it. I plumbed mine into my drain port on the Z rad with an adapter but since I'm swapping radiators soon that's not going to work anymore. I'm not sure what I'm going to use but I think i'm going to use one of the adapter that goes into the upper rad hose and has a 1/4 npt for a t-switch. Either that or just put in a switch. |
Awesome! Thanks for the feedback.....Nick.
tmorgan4
2000 Pathfinder
Fort Collins Co
12-24-2006
| « Re: (npez) | 2:35 AM 5/21/2008 |
Nick have you seen the coolant temp sensor adapters like this one?http://store.summitracing.com/...43215 If your radiator doesn't have a threaded port for one it and you don't feel like welding a bung into one of the tanks this is another good option.
T45
va beach va
6-9-2006
That's the kind of adapter I'm talking about. I'm unsure if the infiniti tswitch will fit in it though. I am going to be taking my rad out soon as well as the switch so I'll be able to tell for sure what wire is the low speed/high speed and get a measurement on the threads. I am going to have to give the switch to my friend that's doing the supra swap, it's getting the Q45 radiator I believe. lol Gotta plug the hole back up.
tmorgan4
2000 Pathfinder
Fort Collins Co
12-24-2006
| « Re: (T45) | 4:57 AM 5/21/2008 |
I was planning on using the fan output on my '94 ECU but I never saw the fan switch to ON when connected through the Consult plug even at around 200*F water temp. When I wired up the relay I ended up wiring my trigger to turn the relay on into the fuel pump wire. It was easily accessible. The only downsides I can see are:1) Extra strain on the alternator since it's always running the fan when it doesn't need to. 2) Since the fuel pump comes on for 5 seconds before the engine is started so does the fan. The fan only draws less than 15 amps max so it shouldn't drain the battery. I can always pull the fuse if the battery is low and it isn't wanting to start. 3) Takes a little longer to warm up. Works for me.
craigztoyz
Austin TX
1-18-2008
| « Re: (T45) | 5:57 AM 5/21/2008 |
Iused one of those radiator T fittings a few years ago, with great success. I Like to use the Painless wiring cooling fan controller for my rad. it is like 80 from summit, comes on at 185, off at 170, fuse it, and give it fulltime power, and you are set, as long as the fans are big enough and so is the radiator. Back to topic, I got my wiring all soldered, and wrapped, de-pinned the connectors, got them through firewall, back together, connected, everything laid out nice, while engine was in place, test fitted everything, just need to extend oil pressure wire, and splice Q alt wire into Z harness, or swap connector.
Once I went through all of it again, and again, and you know, then, made sure it will never get cut into by accident easily. I want to move some wiring more, to keep away from my unwrapped headers. The heat should not be too bad, but rather be safe, been there done that, asked How The *** did that happen? too many times. Now that I found the right bolts, I can hopefully have it up and out this weekend. May have to take J30 to H town.
T45
va beach va
6-9-2006
Did you use the Q harness or the Z harness? The ecu plug will fit through the firewall, it just takes a LOT of finesse and removal of the plastic cover. Took me about 15 minutes but I got it through. The Z plug broke in half when I took it out though but still plugged into the old ECU fine.
craigztoyz
Austin TX
1-18-2008
| « Re: (T45) | 7:55 PM 5/22/2008 |
I cut the Z harness at the firewall, during removal, and on reassembly depinned the connector that goes inside, and first feed the ecu through, PITA, but I got it. All is good, bolts come tomorrow for my crank May start it tomoro for first time in 3 years. almost 4.
npez
Houston TX
8-30-2007
| « Re: (tmorgan4) | 8:24 AM 5/24/2008 |
| Quote, originally posted by tmorgan4 » | | Nick have you seen the coolant temp sensor adapters like this one? http://store.summitracing.com/...43215 If your radiator doesn't have a threaded port for one it and you don't feel like welding a bung into one of the tanks this is another good option. |
I hadn't seen it but that will be a great option! Thanks for locating and sharing this.Nick.
npez
Houston TX
8-30-2007
| « Re: (tmorgan4) | 8:35 AM 5/24/2008 |
| Quote, originally posted by tmorgan4 » | | I was planning on using the fan output on my '94 ECU but I never saw the fan switch to ON when connected through the Consult plug even at around 200*F water temp. When I wired up the relay I ended up wiring my trigger to turn the relay on into the fuel pump wire. It was easily accessible. The only downsides I can see are: 1) Extra strain on the alternator since it's always running the fan when it doesn't need to. 2) Since the fuel pump comes on for 5 seconds before the engine is started so does the fan. The fan only draws less than 15 amps max so it shouldn't drain the battery. I can always pull the fuse if the battery is low and it isn't wanting to start. 3) Takes a little longer to warm up. Works for me. |
That's interesting.... I haven't tried it, but as I'm going with a pre-94 ECU (for tuning purposes) I will most likely go with an aftermarket controller. Something to control the fan came with my SPAL fan based on the Z1 motorsports description, but since everything (fan, radiator, injectors, o-rings, etc.) are still in the box and I'm too lazy to take everything out and put everything back in afterwards, I guess I'll cross that bridge when I get to it.As far as your work around, it's not perfect, but hey if it works for you and since you can live with the nuances of the workaround - I think that's great! You can still take what you have and wire in an additional relay that can be controlled by the factory 3-wire thermo-switch to get around the downsides you mentioned, but at this point that's optional since everything is working just like you have it.... Thanks again for sharing your experience with this.... Nick.
npez
Houston TX
8-30-2007
| « Re: (craigztoyz) | 10:41 AM 5/24/2008 |
Craig,You may also want to consider this wire loom wrap in addition to wrapping your header. http://www.jegs.com/p/Thermo+T...11801 I'm most likely going to coat the headers but will also use this for wiring along the firewall as well as wiring along the frame rails. I'm thinking replacing the plastic loom with this should work nicely.... Just a thought... Thanks, Nick.
npez
Houston TX
8-30-2007
| « Wiring information updates | 2:56 PM 5/26/2008 |
In the next hour I will be posting version 2.3 of the wiring integration document. I have included Ben's and Shane's feedback on the thermo-switch and also corrected some of the wiring information as I found some errors while building mine.An interesting thing I'm trying to sort out is the aux fans. Basically the challenge is that from the wiring diagrams it appears that the Q had 2 fans of which 1 was a 2 speed (dual windings). The Z on the other hand has 1 fan being a 2-speed on the TT. Looking further into the diagram there are some distinct differences between the Q and the Z's activation of the fans. The Q has ECM pin 4 (thermo-switch on the pre-94s) providing relay coil ground for low speed on one fan. For high speed ECM pin 5 provides relay coil ground (thermo-switch in pre-94s) and activates the high speed winding on one fan and also activates the other fan. BTW this could be backwards as it's not indicated in the FSM which relay is high speed and which is low speed - so it could also be that one relay activates both fans on low speed and then activates the high speed winding on one fan for the second stage. The interesting thing is that in parrallel to pin 5 is the A/C pressure switch that can *also* provide ground (the other side of the switch is grounded) and activate the high speed relay. Where it gets interesting is that on the Z the A/C pressure switch is not grounded and connectivity goes through this switch to ECM pin 9. The simplest approach in my opinion will be to ground the other side of the Z's A/C pressure sensor to the chasis (it's by the drier in the nose) and retrofit so it works in similar fashion to the Q's setup. I haven't updated this portion yet on the document until I try it. If it works as I expect I will document it and update the document. Thanks, Nick.
npez
Houston TX
8-30-2007
| « Version 2.3 available | 7:48 PM 5/26/2008 |
Version 2.3 of the document is now available. It has some corrections and integration of the thermo-switch for pre-94 ECMs.You will need Adobe Acrobat Reader (Free download) to open the PDF file. http://www.b2b-now.com/vh45det...g.pdf Thanks, Nick.
npez
Houston TX
8-30-2007
| « Cranking Signal Wire / Clutch Interlock Signal | 2:50 AM 5/27/2008 |
I think I have all of the wires worked out except for 2.1. Has anyone used the cranking signal wire (it is the Black/Yellow wire in the M95 connector in the foot well) when hooking their wiring up? I don't see a destination on the Q45 harness. 2. The Yellow/Blue wire that the FSM on the Z calls neutral switch; is this the clutch interlock circuit (that's what it looks like)? It seems that when the switch is closed it goes to ground. On the Q there is a Park/Neutral Position relay with a Gray wire and a Blue wire. Do one of these wires need to be grounded to signify a Neutral or Park condition? I'm trying to determine the recipient wire to integrate the clutch interlock circuit with the Park/Neutral circuit and if that's the case it makes it easy. If anyone has any insight to this, it would be greatly appreciated. Thanks, Nick.
T45
va beach va
6-9-2006
| « Re: Cranking Signal Wire / Clutch Interlock Signal (npez) | 4:41 AM 5/27/2008 |
| Quote, originally posted by npez » | | I think I have all of the wires worked out except for 2. 1. Has anyone used the cranking signal wire (it is the Black/Yellow wire in the M95 connector in the foot well) when hooking their wiring up? I don't see a destination on the Q45 harness. 2. The Yellow/Blue wire that the FSM on the Z calls neutral switch; is this the clutch interlock circuit (that's what it looks like)? It seems that when the switch is closed it goes to ground. On the Q there is a Park/Neutral Position relay with a Gray wire and a Blue wire. Do one of these wires need to be grounded to signify a Neutral or Park condition? I'm trying to determine the recipient wire to integrate the clutch interlock circuit with the Park/Neutral circuit and if that's the case it makes it easy. If anyone has any insight to this, it would be greatly appreciated. Thanks, Nick. |
I can't recall anything about the starting signal. The interlock wire does not need to be connected to anything at all. I believe that if grounded it will not allow engine to start so hooking up to the clutch interlock is possible, however, even with the interlock wire disconnected the car will still not start with the clutch out. The clutch safety runs through the switch on the pedal before going to the start relay so it's already wired up to work fine with the vh ecu. Easiest to just leave the interlock alone. The wire on the drivers fenderwell that's labeled neutral actually goes to the transmission to indicate neutral to the ecu to allow the IAC to keep the revs up in between shifts on the V6. Not sure if one can incorporate it into the vh ecu or not. It sounds cooler when the rpm's drop fast to me so I did away with that wire....and the iac too!
npez
Houston TX
8-30-2007
| « Re: Cranking Signal Wire / Clutch Interlock Signal (T45) | 9:57 AM 5/27/2008 |
Sweet on all counts! I love it when I don't have to do anything with something. I'll just leave the wires as part of the harness and if something doesn't work right I'll deal with them. I think I'm done with my harness hurrayyy! Now if it all works that'll be a bonus  Thanks for the feedback Ben. Nick.
craigztoyz
Austin TX
1-18-2008
| « Re: VH45DE to Z32 Complete Wiring Integration Document (npez) | 2:32 PM 8/14/2008 |
Pulled this back up to the top of topics for those looking for it. I tried to search for it too, and couldnt get it to find it.WES, METTLER, can we get this Sticky'd Please. There is Critical knowledge in this document that we all need at one time or another. Thanx, Craig
LEMHEAD16
1990 240sx Hatch VH45, 2006 Frontier 4x4, 2009 VW tiguan
Boise ID
5-6-2003
| « Re: VH45DE to Z32 Complete Wiring Integration Document (craigztoyz) | 2:08 PM 10/14/2008 |
Main link does not work anymore! Can we host it on NICO?
 VH45 S13. KTS coilovers. Megan RUCA's. Weds Farmas 17x8 +8. Bridgestone Potenza 225/45/17, bald rubber. CATCO cat. Magnaflow muffler. Built by me!
npez
Houston TX
8-30-2007
| « Re: VH45DE to Z32 Complete Wiring Integration Document (LEMHEAD16) | 4:19 PM 10/14/2008 |
| Quote, originally posted by LEMHEAD16 » | | Main link does not work anymore! Can we host it on NICO? |
Link corrected. I can't host on iServe as it doesn't accept PDF! I can't send it to NICO as I need to also have access to it as if I receive comments/updates, I want to have 1 system of record so the changes to get mixed up.Try it now though it all works..... Thanks, Nick.
Panther in a Q45a
1995 Q45, 1994 Q45, 1974 Pantera, 2006 Hummer
Lincoln NB
7-9-2008
| « Re: (tmorgan4) | 5:10 PM 10/14/2008 |
Long time since the original message, but here is a source that is more affordable. http://cgi.ebay.com/ebaymotors...91561
LEMHEAD16
Boise ID
5-6-2003
| « Re: (Panther in a Q45a) | 10:52 PM 10/14/2008 |
Thanks for fixing the link
craigztoyz
Austin TX
1-18-2008
| « Re: (LEMHEAD16) | 1:26 AM 10/16/2008 |
On the wiring, I did not hook up a starting signal. works greatDid not connect the 5v? sensor wire to anything, no problems did redo all the grounds, and add extras, have not had any issues. I have not had the EGR hooked up, or the air bypass valve, although the other engine I have has the complete intake and am going to use it on the dyno to see if there is a difference between with and without EGR/airbypass. Even with it cold in the mornings, it has not been an issue, runs good from startup, great after a minute. Idle is never an issue. the connectors are just chillin there taped over. I did put in a major modification to the engines wiring harness, that allows me to run it in 4 cyl mode, giving me about 6mpg better, and still willl easily accerate on the freeway to pass people. I will be having this as an option on my swaps, and the harnesses I sell. If you get a large enough aluminum radiator, and have enough air in the front, you will rarely need the cooling fans to be on. Hope my experience helps, Craig
SuperHatch
Manahawkin NJ
11-17-2006
| « Re: VH45DE to Z32 Complete Wiring Integration Document (npez) | 5:58 AM 10/21/2008 |
| Quote, originally posted by npez » | Link corrected. I can't host on iServe as it doesn't accept PDF! I can't send it to NICO as I need to also have access to it as if I receive comments/updates, I want to have 1 system of record so the changes to get mixed up.Try it now though it all works..... Thanks, Nick. |
Nick, I'd be happy to host the PDF on my site. Just email any time you have an updated version and I'll change it within a day or so.
SuperHatch
Manahawkin NJ
11-17-2006
| « Re: (craigztoyz) | 5:59 AM 10/21/2008 |
| Quote, originally posted by craigztoyz » | | On the wiring, I did not hook up a starting signal. works great Did not connect the 5v? sensor wire to anything, no problems did redo all the grounds, and add extras, have not had any issues. I have not had the EGR hooked up, or the air bypass valve, although the other engine I have has the complete intake and am going to use it on the dyno to see if there is a difference between with and without EGR/airbypass. Even with it cold in the mornings, it has not been an issue, runs good from startup, great after a minute. Idle is never an issue. the connectors are just chillin there taped over. I did put in a major modification to the engines wiring harness, that allows me to run it in 4 cyl mode, giving me about 6mpg better, and still willl easily accerate on the freeway to pass people. I will be having this as an option on my swaps, and the harnesses I sell. If you get a large enough aluminum radiator, and have enough air in the front, you will rarely need the cooling fans to be on. Hope my experience helps, Craig | Cut power to one of the power transistors?
| First 1 2 > Last |
