bumblebtuna »
https://forums.nicoclub.com/bumblebtuna-u54742.html
Mon May 05, 2008 11:13 pm
yeah, my buddy's screamin in my ear to get an aftermarket rail but i'm broke ..just got in another apt and rent is a *****...ha go figure. so yeah, fuel rail as been grinded smooth, just need to cut/weld the brackets to it. and throw everything else together. fuel filter, air filter needs a stepdown coupler, solder tps, and cut into the upper harness...... again.. wire up efans, belts, still need to run the battery cable to the trunk for the reloc. , fuel pump, power steering hose, coolant lines, oil, gas, coolant, luck... have a bad feeling one or more coilpacks will be shot
should have the money for bigger injectors, 44mm or bigger W/G, manifold of some sort, and stronger clutch by the end of the summer maybe sooner. then we'll see what that turbo can do. i bought it so soon because it was a hhhheeelllof a deal i couldn't pass it up.
it's an authentic garrett 35R center cartridge, precision .63 ex housing. .70 a/r compressor housing. i'm hoping it'll spool like a 3076r just a little longer but make more top end. hoping i won't regret it and wish i'd gotten the .82
