From all the messes I've made in my younger days doing fluid changes, I've learned to wear gloves, spread newspaper on the floor, keep my rags and towels right next to me, and strategically place my drain pans. Once a year I usually bring all my bottles of waste fluid to the county disposal site for recycling along with my other household recyclables. So for me, it isn't too much of a hassle.XIS wrote:Now the main reason I don't do things like fluid changes is just because I don't want to deal with disposal or make a mess!
My daughter is still young, but I'm hoping to be able to teach her some of this stuff before it gets too hard for me to crawl under the car and do these things. Besides, she fits under there a lot more easily than I doXIS wrote: I may start doing that again since my oldest is almost driving age and he needs to learn this s*** too!
I have no experience with Lexus, but my sister used to have a VW. Honestly, it was a joy to drive. I didn't do much work on her car, but the couple of minor jobs I helped her with, along with perceived German reliability, complicated assemblies and layouts, and dealership service dept. horror stories really scared me away from even considering one.XIS wrote:I came from VW, Lexus and Acura. There is a ton more info out there for those cars, but this forum is picking up !![]()
The mileage interval for those powertrain fluids is the big question...XIS wrote: Can the ATF and Diff fluids wait till 60K?
If I get the chance, I'll put up a post in the "Infiniti Online Mechanic" section to ask about the differences between the model lines. It appears that the many model years of the EX, FX, G, and M have a longitudinally mounted VQ engine variant, 5spd A/T, standard RWD and optional AWD. And there are a good number of How-tos availble for these cars. I'm interested to find out where all the similarities end. Since the EX is based on the G platform, I'd imagine that they are the probably closest to being the same. From some of the photos I've seen, the EX's and G's dashboard and center stack look nearly identical.Tasman wrote: 4. Cannot answer. You need to talk to an authorized mechanic to answer that.
The Infiniti Premium service says to replace the ATF, differential, and transfer case oils at 30K intervals; Schedule 1 says to inspect at 15K intervals, and to replace at 30K intervals if towing a trailer, using a camper or car-top carrier, or driving on rough or muddy roads. Obviously towing is not recommended with the EX and campers do not apply here. I'm guessing most of us don't use a car-top carrier year-round. And rough and muddy roads, while open to interpretation, are what I'd think: unpaved surfaces. Otherwise, there is no change interval for these fluids in Schedule 1 or 2 services. So unless you're following the Premium service schedule, there doesn't seem to be any mileage interval for changing those fluids.Tasman wrote: 5. Follow the Infinti recommended service on the power train components to keep your warranty valid. Keep your receipts and make sure that your mechanic uses the fluid specifications required by Infiniti.
For anything warranty related, I let the dealer handle it. It's on their dime, it gets documented in their system, and they're the ones held accountable if any related issues arise. I'd only perform a warranty fix myself if the dealership service dept. is totally incompetent and I have the means to do it. Fortunately, I've never had that experience.Avalanche325 wrote:I will take the car in to get a warrenty item fixed, because why pay for the parts?
For the first oil change, I might spend about 5 minutes trying to figure out the underbody pan/cover. Once I figure it out, I'll be comfortable with the rest of the job.Avalanche325 wrote:So far on the EX I have done the following:
Oil/filter change. (Extremely easy on this car)
Air filters (Easier than extremely easy)
Drive belt (medium compaired to other cars I have done)
Front and rear brake pads with fluid change (easy)
TIre rotation (Would have been easy if the donk that owned the car before me had put the wheel lock key in the car)
permanent wire-in of a radar detector.
Added an on/off switch and a mute / volume switch next to the sonar off switch.
I might come back to you with questions on this as well.Avalanche325 wrote:Next jobs:
ATF change (I will be using the Nissan ATF after what I have been reading)
I've downloaded the manuals and have briefly looked through some of them as well. While FSMs are great, they sometimes don't show some of the other steps needed to gain better access to what you want to work on. I guess in those cases, I'll have to make use of my brain and do some actual thinkingAvalanche325 wrote:I would reccommend downloading the manuals that are available here. These have all of the procedures that you need and then some. They also have torque specs, etc.
It is really easy on the EX. You have to take the splash pan down, which is the majority of the effort. It is made where if you had a lift, you only take the bolts out of the front and it hinges down. I am not that lucky. Anyhow, take out all the 10mm bolts, then there are three plastic plugs that you use a flat blade screwdriver on to pull the center out and the pan is off. The nice thing is that if you have a decent sized drain pan you can pull the plug (14mm IIRC) and change the filter with it all dripping in the pan. It is a clean shot to get the filter, so no mess at all. When putting back together, use the three plastic plugs first and they hold the splash pan in place.NJGuy wrote: For the first oil change, I might spend about 5 minutes trying to figure out the underbody pan/cover. Once I figure it out, I'll be comfortable with the rest of the job.
If it takes 5 minutes, you are taking your time.NJGuy wrote:
The air filters look very straightforward.
Yep. Just give us a yell. Not too bad. The big thing is the routing pattern, which is in the owners manual. Also "pin" the tensioner in the slack position.NJGuy wrote:
When the time comes to change the drive belt, I might come back to you with some questions.
No differance. Just use the old pad when pushing the pistons back in.NJGuy wrote:
I've only changed brakes on single piston calipers, so I might have to take a minute or two to figure out the difference on a dual piston setup.
I have always done front to back. Early radials had issues with X. Probably not applicable today. But, Infiniti says F to B so I am sticking to it. My wear pattern looks very even.NJGuy wrote:
My tires are not directional, so I don't like Infiniti's 'front to rear' rotation pattern. I'll probably just do the 'X' pattern like some of you guys have recommended here.
XIS, I would like to change the interior lights to white LED lights as well (and the running lights); can you tell me where you got them, and which model/part no. you got please?XIS wrote:I do a lot DIY... changed out all my interior lights to white LED and also my running lights too. ?
Based on requirements, the EX35 isn't very picky on oil.XIS wrote:About to tackle my first DIY oil/filter change.
I was going to use either Mobil 1 or Castrol Synthetic. Any preferences out there?
What about the oil filter. Which non-oem filter do you like?
IMO, I don't think it matters too much what kind of oil you pick as long as it meets the vehicle's requirements. In our case, it would be a 5W-30 that's SM rated. With all the advances in lubrication technology and reliability of modern engines, I'm pretty sure that if you follow the recommended maintenance, the engine's internal components will still be working just fine when you finally get rid of the car. How many oil related engine failures (not defect related) on properly maintained engines do you hear about nowadays?XIS wrote:About to tackle my first DIY oil/filter change.
Actually, the oil does make a tremendous difference... I've seen engines apart that were running on conventional oil that were all sludged up - same engines on synthetic looked fine. HOWEVER, with the short OCI's recommended by Infiniti (conventional or synthetic), it's probably fine to use either.NJGuy wrote:IMO, I don't think it matters too much what kind of oil you pick as long as it meets the vehicle's requirements. In our case, it would be a 5W-30 that's SM rated. With all the advances in lubrication technology and reliability of modern engines, I'm pretty sure that if you follow the recommended maintenance, the engine's internal components will still be working just fine when you finally get rid of the car. How many oil related engine failures (not defect related) on properly maintained engines do you hear about nowadays?XIS wrote:About to tackle my first DIY oil/filter change.
While synthetic oils are nice and may provide better protection than conventional, I don't believe that we'll really be able to see any noticeable difference in engine wear in our street driven vehicles. If you like to pamper your vehicles, there's nothing wrong with using a high quality synthetic oil. I'd say that the biggest advantage synthetics have over conventional oils is that they usually provide protection over a longer period of time; so you could probably run a longer oil change interval.
While I'm still under warranty, I'll just stick with a brand name conventional or semi-syn oil, good quality filter (likely OEM), and the 3,750 mile OCI. Once the warranty is up, I might consider moving to a synthetic (doesn't matter to me if it's a Group III or IV), a better filter, and a 5,000-7,500 OCI to lessen the number of times I have to get under the car.
Hey NJGuy-NJGuy wrote: So to sum up my questions:
1. How many of you do your own maintenance and repair work on your EX? If you do, what is the extent?
2. For those that DIY, would you be willing to post step by step instructions on the maintenance/repair items you perform, as well as taking pictures along the way?
3. Have many of you moved from other Nissan/Infiniti products to the EX?
4. How similar are the EX, FX, M, and G series mechanicals to each other? Are some of the procedures done on the FX, M and G models identical to those done on the EX?
5. Does anyone have their own recommended schedule for ATF, transfer case, rear diff, and other fluids, that varies from Infiniti's recommendation?
Thanks in advance.
Hi Tim,TimGinCentralNJ wrote:
Hey NJGuy-
I live in Bloomsbury if you know where that is. And welcome to the fold
FWIW, I do know there are some folks here who DIY, but for the most part I think you'll find since most of these cars are relatively new overall, this won't be like many online DIY forums you may be familiar with...at least not until our warranties start expiring![]()
I purchased an extended warranty from Infiniti so I'm covered for the major stuff for a while yet, however, even though I don't work on my cars as often as I used to pre-kids, I'm not totally sure I can justify laying out the cash for the milestone service intervals you referenced. So, I may be doing more of it in the near future. To date, I've only done rotors and pads on my 2008 EX (speaking of which, if you need a recommendation on some good aftermarket pads/rotors, let me know. The OEM brake parts are good, but do not last). I have documented a fair amount of the work which I've done on my old bmws, and would have no problem doing that on my EX when the time comes.
I, too, am curious about the transmission service interval. At least in my travels anyway, waiting until 60K or longer sounds like asking for trouble, but again--I am still getting to know these cars myself.
Sorry I didn't answer any of your questions, but looking forward to seeing you 'round the board....
Tim
Great info, NJGuy....thanks for sharing with us.NJGuy wrote:Just wanted to share some notes, thoughts, and opinions after doing the 30k maintenance.
Nice! I love the idea of a bike, but between A.) living in the most densely-populated state (by size) in the country, combined with B.) the white tailed deer over-population problem we have (the result of ineffective population reduction efforts due to A.), NJ is not a good place to own a bike, IMO.EXceptional wrote:Can you do me a favor... and take some pictures the next time you have to do yours?
I guarantee you'll be changing yours before I get around to doing mine anytime soon.
We are lucky if we change our Oil once a year. Our vehicles are parked quite a bit, because we have Motorcycles.
XIS wrote:Happy to help.
That was a great and easy mod (LED lights) and I feel your pain as far as trying to decide which ones to use, etc. There are a lot of types and sizes, then there are different numbers of LED's in each, etc.
Here is what I used… you can select different amounts (or colors) of LEDs per light, depending on your preference.
• Hatch - these take the 31mm festoon bulbs. I used the ones with 16 led chips on each. – two of them… http://www.ebay.com/itm/2-X-White-Dome- ... 4ab0ef14a4
• All others were wedge bulbs.
• Running Lights - I used two 25 chip LEDs - http://cgi.ebay.com/ws/eBayISAPI.dll?Vi ... 8943419009... Initially I had 5 chip bulbs here but wanted something brighter. I put them in my wife’s car. http://www.ebay.com/itm/One-Pair-T10-28 ... 519be9be7b
• Map, Passenger and Door lights - I used six 10 chip LEDs - http://cgi.ebay.com/ws/eBayISAPI.dll?Vi ... 0677718731
• Driving lights – I tucked a strip under the front bumper in that small 1/8” or so gap and wired them to the driving lights. You can not see them unless they are on. http://www.ebay.com/itm/LED-WHITE-2X-12 ... 2a134185af
• I ordered my wireless rear view camera and when I wire that to my reverse lights, I will update the license-plate lights to LED too. I think they are also wedge bulbs, but I have some festoons left over just in case!
Good luck!
Oh - and by the way ...relating to the oil change above, I used Castrol Edge synthetic and a K&N oil filter.
