getting back on topic...
jmess wrote:This topic has been kicked around before but I still finding it amusing, more so since it just happened to me. I took my car in for an oil change at 30K and expected a service pack sales pitch but was pretty surprised at the total. There wasn't any high pressure but you have to believe a lot of folks get taken for the ride.
The inspection report flagged all my fluids as "visibly dirty" and needing to be flushed and replaced. Of course my PS fluid was on the list. The report even had color pictures of parts damaged by "dirty fluid". The quote to hook up all the flush/fluid replacement machines was $740. If "dirty fluid" is at pandemic levels at 30k shouldn't the PS fluid flush be included in the $900? Nobody applied any science like testing my coolant to see what condition it is really in. Nobody tested the brake fluid to see what the moisture content was.
Here is what $900 get you:
Oil change ( cost me $40 with one of their coupons and includes a safety inspection, wash, and vacuum)
replace air filters (did it myself in 5 minutes)
replace brake fluid (I will pay my mechanic buddy $50 and provide the fluid )
transmission flush/replace (Nissan doesn't approve of the flush process; I will do a drain and fill at 60k)
engine coolant flush/replace (Will do next fall)
wiper blades replace (did it myself in 10 minutes)
drive belts replace (30K is a little early, the belts still look great)
replace transfer case oil (my car is 2wd so do they drop the price?)
test the horn, lights, wipers (does your horn beep?)
replace differential oil (will do at 60K, easy to do myself)
rotate tires (I get it done free at Americas Tire)
correct tire pressure (free at any tire store and included with the oil change)
clean sunroof drains (do they make SR drain flush machine? Never had a SR drain issue, easy to fix if I did)
adjust parking brake (Need to check this, looking at the EX shop manual the adjustment process is easy)
replace cabin air filter (did it myself, 25 minutes)
perform 27 point inspection (the important stuff is included with an oil change)
What follows is part of the 27 points they already sold you??
inspect fuel an vapor lines (did it myself 10 minutes)
inspect brake pads and discs (part of the oil change inspection and the 27 points they already sold you)
inspect exhaust system (They do a visual during the oil change)
inspect suspension (did it myself 5 minutes)
inspect steering gear. (did it myself 5 minutes)
Their Total $899.
My total, about 1.5 hours and $150. If they would have offered me a more reasonable pack at say $300 I might have went for it if it covered what I felt was important.
I just completed an oil change this past weekend and performed lots of inspections while the wheels were off and I was under the car. Comparing your list with the service manual (SM) for the schedule 1 30K maintenance, here are the items on your dealer's list, along with the comments in the SM.
Oil change (
cost me $40 with one of their coupons and includes a safety inspection, wash, and vacuum) - given.
did it myself in 5 minutes) - due at 30k, could not be any easier.
I will pay my mechanic buddy $50 and provide the fluid ) - Not even listed under the "Premium" Maintenance. SM only calls for inspecting the brake fluid level periodically (according to Nissan,
each time you check the oil or refuel), which obviously should be between min and max; the SM says nothing about fluid condition though. However, the maintenance section does have the procedure for brake fluid replacement. Although Nissan doesn't specify when to change this, it's not a bad idea you're having it done.
Nissan doesn't approve of the flush process; I will do a drain and fill at 60k) - SM calls for an inspection of the ATF at 30K. It only calls for replacement
if towing a trailer, using a camper or a car-top carrier, or driving on rough or muddy roads. Further, the SM calls for ATF replacement if it shows signs of
being varnished, milky white or cloudy, or having a large amount of metal powder mixed in. My ATF looked incredibly clean, but I might do a drain and fill at 60K or earlier depending on future inspections. You might want to pull the A/T dipstick to see if the ATF is "visibly dirty" like the dealership claimed. I couldn't see the dipstick until I removed the plastic engine cover.
Will do next fall)- SM says:
After 60,000 miles (96,000 km) or 48 months, replace every 30,000 miles (48,000 km) or 24 months. Also has a "*", which says:
*Maintenance items and intervals with “*” are recommended by INFINITI for reliable vehicle operation. The owner need not perform such maintenance in order to maintain the emission warranty or manufacturer recall liability. Other maintenance items and intervals are required.
did it myself in 10 minutes) - Common sense should prevail here.
30K is a little early, the belts still look great) - SM says:
After 60,000 miles (96,000 km) or 48 months, inspect every 15,000 miles (24,000 km) or 12 months. Replace the drive belts if found damaged or if the auto belt tensioner reading reaches the maximum limit.
my car is 2wd so do they drop the price?) - Funny. For the AWD owners:
If towing a trailer, using a camper or a car-top carrier, or driving on rough or muddy roads, change (not just inspect) fluid /oil at every 30,000 miles (48,000 km) or 24 months.
does your horn beep?) – Well, sometimes people are oblivious to burned out tail lights. SM also says to check headlight aim; but really, I’ve never had mine need adjustment in any of the cars I’ve owned.
will do at 60K, easy to do myself) – again, SM only calls for replacement if towing a trailer, using a camper or a car-top carrier, or driving on rough or muddy roads. And I thought rear differentials typically had a long change interval? It probably makes sense to change if you see metal filings in the fluid. Also, I posted some general maintenance questions in the Infiniti Online Mechanic forum; the one member who responded recommended to do a few drain and fills of the rear diff early on.
rotate tires (
I get it done free at Americas Tire) – Due at 30k. SM says every 7500 miles.
free at any tire store and included with the oil change) – I guess this is for the people who are clueless about how a car works.
do they make SR drain flush machine? Never had a SR drain issue, easy to fix if I did) – No mention in maintenance section SM. It’s a nice reminder though if you happen to open your moon roof a lot and frequently park under trees.
Need to check this, looking at the EX shop manual the adjustment process is easy)- SM says:
should be checked on a regular basis, such as when performing periodic maintenance, cleaning the vehicle, etc. It also says to
check that the pedal has the proper travel and make sure that the vehicle is held securely on a fairly steep hill when only the parking brake is applied.
did it myself, 25 minutes) – due at 30k. Usually a rip-off at almost all dealerships.
What follows is part of the 27 points they already sold you?? – You have to wonder sometimes how they price this stuff…
did it myself 10 minutes) – due at 30k, with a “*”.
* Maintenance items and intervals with “*” are recommended by INFINITI for reliable vehicle operation. The owner need not perform such maintenance in order to maintain the emission warranty or manufacturer recall liability. Other maintenance items and intervals are required.
art of the oil change inspection and the 27 points they already sold you) – due at 30k. I bet that they just do a quick visual inspection to check for obvious issues and estimate the thickness left on the pads. The SM has the measurement limits for pad thickness, rotor thickness, rotor thickness variation (measured at 8 positions), and runout. Do you think the tech honestly brings out their calipers and other equipment to measure this stuff if the owner did not report braking issues?
They do a visual during the oil change) – Interestingly, the SM says that this
should be checked periodically (e.g. each time you check the engine oil or refuel). Next time I gas up my EX, you’ll find me under the car
did it myself 5 minutes) – both due at 30k.
Other items listed in SM due at 30k that may or may not fall under your dealer’s 27 point inspection:
Brake lines and cables – Inspect.
Propeller shaft and drive shaft boots (AWD models) – Inspect.
