That's the size I'm running but with a Lil stretch (9"F and 10.5"R wheels) for you're size wheels they wouldn't be stretched...but again, your current size will work!!
Thanks for the help Mex!! I knew the numbers seemed a bit lopsided but wasn't 100% sure!! At 9.5" Rear an offset of like +35 would be a better match to the front numbers!!mexillis wrote:CPJ LB you wont be able to run 275's unless you get some fender pulling. You might have to run a 255 in order to pull off those wheels in those specs. If you do get them that aggressive in the rear it wouldn't make sense to have the fronts inside the fenders. A +15 or +10 with a 225 would probly match the rear.
M35xPA wrote:It's just B T Full!
LOL, all of your wheel choices up until this point were utter rubbish. Now these vossens are pimp. I wanna get this s***.The Bodyguard wrote:![]()
OOPS I DID IT AGAIN GUYS!!!
NEW VOSSEN CCS-CV1 MATTE/GRAPHITE 20" STAGGERED WHEELS ON NITTO RUBBER!!!
Actually 22"x9" Vossen dropped on eibach look awesome on the 08+ M!! I've seen it first hand in person!! And about the wheels being rubbish except the Vossenradigan wrote:Oh and I think 22s on this car is overkill. 20s are a nice fit.
I've seen this one before!!!mexillis wrote:I found your new ride bodyguard!
