biosehnsucht wrote:My CP Pistons are 84mm, not sure what the actual bore spec was, but I went with what was on the sheet they sent me (I just gave it to the shop...).
Why would you bore them smaller than the pistons? Are they underrated that much? I mean even if it was 83.42mm cold and 83.5mm hot, if you only bored to 83.42 then you're in trouble once it heats up...
My CP "83.5mm" set, as in "+0.5mm", as in first service oversize, were actually of 83,38 - 83,39mm diameter (IIRC) (SKIRT, not top, before someone jumps on me
). With the piston-to-bore clearance requirement on the spec sheet I got with it, my bores needed to be around ~83,42 or ,45. Again, IIRC. But it was most definitely NOT a 83.50mm bore, that it called for, it was way under that. The member that made that comment might have got the same kind of pistons as me.
I got my set from frsport, and on the spec sheet I got, the "Customer" field said "Phase2"... I'm guessing what I got may have been an old Phase2MT custom order on file. Other custom CP orders for the CA-DET may have had different dimensions, different material, and as such, different requirements for bore size. Mine were high expansion, low silicon ones. Who knows if you'll get the same if you order elsewhere...
If you don't have the measurement tools necessary, just hand over the spec sheet and the pistons to the shop when you drop the block off. Don't just give them the block and ask for 83.50mm. Wait until you have your pistons.
