burntricer »
https://forums.nicoclub.com/burntricer-u53313.html
Thu Feb 19, 2009 3:37 pm
Here is the story,
Last year, around this time my sr was running like a bag, super rich, only pulling 10 vac on the gauge and sucking back gas like there was no tomorrow. I fought with it, months and months, and thousands of dollars later i got it working perfect, it was the CAS plug the whole time, i replaced the entire harness to make sure that i had nailed the problem. it was perfect. Fast forward 8 months, it started to run bad again, pulling 16 inhg on the vac gauge, and slowly, over those months, it has gotten worse and worse.
like it still idles dead on 1000 rpm, its only pulling 8 InHg, running between 13.9-15.0 afr, idles like its missing, and when your into boost it doesnt pick up till around 4500, but its in full boost at 2200
heres what ive checked so far
compression (cold) - 138 , 140, 141 , 139 (within spec)code -55fuel pressure - ~42 w/ vacboost leaks/intake leaks - couldnt really find anychanged MAFS'
Now mind you, my timing is advanced right now, significantly,I put the BC 264 cams in and i cranked it over by hand, and then i hit it with the starter, it made a wicked bang, but it ran, with a tick, so i pulled it apart again and the lifter was fine, but the rocker was broken... changed that out, changed all my intake mani gaskets and my Iacv gasket.
If i set the timing dead on with my light, it barley runs, and thats me putting it in timing mode (warm with the TPS unplugged)the mechanical timing is dead on, the Iacv is working, i can control the idle speed with the screw, im not getting any codes whatsoever. my harness is new, so im confident its not electrical, i deleted my SAFC to make sure that its not whats causing the problem
what gets me, is it was running great last year until around august this started to come in, its gotten worse and worse since ive been driving it, now when it idles, it idles at 14ish afr, 850 ish rpm, but it sounds like a drag truck and only has 8 InHg. only when it warms up tho, when it is cold it idles around 1500, and around 13/12 afr...
do you think it could be a leak between the turbo and the exhaust mani? what other things could it be, im really kinda stumped. The last time this happened it was the CAS plug, that fixed it no problem, but ive checked that, and changed CAS's....what about the alternator, ive noticed once and a while the lights seem dimmer then usual and i know its gotten salt and shiv in it alot recently, along with oil from my front main seal leak and coolant from changing throttle bodies....?
Ive verified my alternator is putting out 14+V, ive changed my plugs, they are gapped properly, i verified no vaccuum leaks, and i checked for vacuum leaks, i found one, fixed it, nothing changed. so then i figured, to eiliminate that I would induce one. No change.
Seriously im at a complete loss, this motor just hates me. any thoughts, or maybe point me in the right direction?
Im going to try to get a video tonight or tomorrow...
