Ok I am going to be honest here(I have made so many mistakes I can no longer keep track!) I had the fuel gauge hooked up wrong during the Dyno tests. The fuel gauge was hooked up between the FMU and the FPR. I went to a friend of mines house and he pointed it out to me( I will leave his comment out of this one). So we hook it up on the pressure line between the fuel filter and the fuel line. The pressure was reading around 35 which is what it is suppose to read. He starts applying pressure to the FMU at idle and it only goes to 50psi. So he gets out his vice grips and clamps the return line and it goes up to 60psi. We drive it again with the vice grips on and this time it doesn`t bog until it hits 10pounds of boost. The waste gate is suppose to open at 8. So I sent off the FMU to BD yesterday morning and I ordered this tool kit today.
http://www.mityvac.com/kits.ht...vekit
It will test my FMU, BOV, wastegate and vacuum sources. Also bleed your brakes and Clutch. Apply pressure to your radiator to check your radiator cap and for leaks. I wanted a tool to tell me what actuated devices works and what doesn`t work so now I no longer have to guess. I only paid 67bucks shipped. IMO I think everybody who plans on boosting should have one of these kits and a fuel gauge.
I have made so many mistakes I hope somebody will be helped by my stupidity!!
