Ajax »
https://forums.nicoclub.com/ajax-u5731.html
Fri Apr 03, 2009 12:06 pm
So I decided to try out the Xcessive manifold for the KA engine to go with my built engine.There’s a lot of back-story with this engine, but the current state is a 2.6L stroked KA built by AMS with an AMS race-prepped head, 10.5:1 compression, BC V3 cams, header, exhaust, tuned with JWT ECU and piggyback AFC NEO (soon to be retuned), flywheel, driveshaft- pretty much way more money than I really needed to spend.Anyway some of you know my car, some don’t, but I wanted to share some pics and progress.Here’s the manifold runners and plenum straight from the box.There are some casting imperfections in the plenum.So I’m thinking- I can cover that up by painting it. That’ll be fun, but let’s make it pretty by the details. Mmm, embossed lettering…So I pull out the masking tape.FAIL!!!Don’t know why I thought masking tape was going to mask this adequately with the rough cast surface of the runners. But since the paint stripper I had used to prep the surfaces seemed to do well, I thought, why not give it a try. A few hours with stripper and q-tips…Win!So I didn’t want another masking tape fiasco for the (X) design on the plenum, plus that’s time consuming. What could I use to temporarily mask that design with minimal effort?Well, the glue kinda worked. Since it was a curved surface, it was tough to make dry within the stamped design. Also, while it did keep paint off when I sprayed, it tended to peel up some of the paint with it. If you’re careful with an X-acto knife, this method can work. I ended up masking with tape again, respraying, using a fine blade and peeling tape and wha-la!I should have this manifold installed on Sunday. It won't be out of storage officially until a little later this month (MN spring is too unpredictable, and I gave away my snow tires) It won’t be really tested thoroughly until I have it retuned by AMS- I’m hoping this will really open up the top-end, but I don’t want to gun it for fear of running lean with all the extra air (maybe I’m being overly conscious, but you would too, with this much money spent).
Modified by Ajax at 8:16 AM 4/19/2009
Modified by Ajax at 8:17 AM 4/19/2009
