90’s250sx wrote:vinnie you sound like you know what your talkin about pretty well with the velocity. i am wanting to go all motor also with time. its all in idea right now but got to have a plan to start getting the funds so what kind of compression can you run on pump 93 gas does it have to be non ethanol or regular gas? ethanol raises the octane by 1 or 2 points does it not? the only problem i really see with all motor is the intake manifold and throttle body. in my opinion i think the throttle body needs to be slightly bigger than the stock one 5 to 10mm and with port and polish and bigger valves check my forum out man.
zerothread?id=483743
I don't want to ajck Ajax's thread so I will keep it short.
On 93 pump gas you won't want to go any higher than 10.5:1. That is if you keep the ecu stock and use 310cc injectors which would be needed to keep the A/Fr's consistent with that compression ratio.
As far as velocity is concerned with runners do not over kill runner diameter's stock runner diameter is 44m, there is no need to exceed past 45mm.
Your TB can be bored there is really no need to exceed 64mm, there are a couple principles behind this logic, not only because the TB itself becomes a weak structure after 64mm.
When raising the compression always take squish and quench factors into consideration. If you have a pentroof head you will want a piston dish that is concaved in shape. If you have a hemispherical head you will want a piston dish that is flat in shape. thi shas to do with the properties of flow and swirl in the chamber, and believe it or not 90% of people building a high compression KA get this wrong, and get low results in HP.
Sorry to thread jack.
