Rusty Shackelford wrote:It's not a matter of what lights are used. But Canada requires that the lights come on when the ignition is on and the car is running without having to turn anything on (except the engine) and the DLRs go off when the headlight switch is turned on. So it doesn't matter what light is used, the logistics of how they operate still needs to be figured out, hence the interest in this.
i'd make the DRL's the foglights. this way when you turn on your headlights, the foglights are on, and no one will be the wiser. this is a simple 5-pin relay module.
30: 12v from battery
85: ground
86: trigger (tap positive wire from the low beams)
87: 12v power to DRL lights (only send power when there is signal from trigger)
87a: 12v to DRL (only sends power when no signal from trigger)
hook up the ground.
get power from the battery
tap the trigger wire from the low beams
use pin 87A to send power to the DRL lights
leave pin 87 blank.
this way when the headlights are off, the relay will send power to the DRL lights. as soon as the headlights are turned on, the relay will cut power to the DRL lights.
