noyou cantbecuase hte wheel is moved so far back in the wheel well, it hits the bumperRBbugBITme wrote:
"If you add more camber at a super low height, the toe gets all jacked up, then when you fix the toe, the wheel position in the wheel well gets jacked up (caster).I mean, you CAN just fix the toe, but your handling might be a little weird in some instances than before."
Modified by RBbugBITme at 12:17 PM 12/26/2007
so unless you have physically done it, shut the **** up.would you lik epictures?i hvae to redo my setup tomorrow since i had to put stock wheels back on to go to the land office, so i have to readjust everything back to extremes...i mean, i can hold your hand, nad show you if youd like...
