A/C unit temperature reads in Celsius
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
I'm pretty well convinced it has to be the Auto Amp that's stuck to the bottom of the HVAC Unit. That shouldn't be hard to change either, there's only one screw holding it in (although it's in a somewhat awkward spot). Finding the right p/n for a particular MY and trim level is the real problem with that. There are a whole bunch of different ones listed for US models across the gen2 Rogue's lifespan.
ikalinin
Car: 2018 Infiniti QX60 Deluxe Tech
2018 Nissan Rogue SL
VStar650CL wrote:
Mon Sep 20, 2021 4:54 pm
can you elaborate on this?
VStar650CL
Technical Expert
If you pop the cover at the front of the console beneath the glovebox on the righthand side, you'll see it immediately. It's screwed to the bottom of the HVAC housing with (I think) two connectors coming out of it. The Auto Amp is what actually controls the heat and A/C systems, the panel up front is only buttons and a display.
ikalinin
VStar650CL wrote:
Mon Sep 20, 2021 5:11 pm
bingo. bought the new part (oem part # 277609TG0D)
remove the pass side trim below the glovebox, there is 1 screw towards the middle of the car. you'll need a shorty screwdriver, or a right angle socket. 1 screw, and then it simply slides off.
fixed the readings to F :)
thank you!!!
VStar650CL
Technical Expert
Sweet. Happy (Fahrenheit) motoring!
SmyQ
Car: 2018 Nissan Rogue SL AWD
ikalinin wrote:
Fri Oct 15, 2021 12:40 pm
thank you!!!
Are you still in possession of the old part and can you provide its number? I bought the US version two weeks ago, and I would like my car to display Celsius instead of Farenhait on A/C.
I would be very grateful for your help.
ikalinin
oh man.. we could of just swapped parts! :)
yes, i have it. where are you located. PM me.
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
ikalinin wrote:
Thu Nov 18, 2021 11:34 am
Just a heads up...
New members with less than 10 posts cannot send/receive a PM.
ikalinin
I guess message me here then! :)
SmyQ
That's good idea, but i'm from Poland. It will take long time for delivery, and I'm not 100% sure this part can solve my problem. If not, then I'm gonna stay without anything, and my wife gonna kick my a** :(
VStar650CL
Technical Expert
SmyQ wrote:
Fri Nov 19, 2021 1:31 am
Actually, USPS to Poland is pretty prompt. Usually 8~14 days for First Class International, I'd say 11 is probably average. I've also bought electronic components from Poland and those were prompt too, under 10 days.
Rogue One
2022 Honda Pilot SE
Rogue One wrote:
Thu Nov 18, 2021 5:57 pm
Just a heads up...
:facepalm:
Had a senior moment as I'd forgotten that I had to manually set up an account for SmyQ. Anyway, I've upgraded his account to allow PM's.
VStar650CL
Technical Expert
ikalinin wrote:
Thu Nov 18, 2021 6:28 pm
I just got a PM from you that I presume went to the wrong place, you want @SmyQ. Resend as/if needed.
ikalinin
send me a pm.
SmyQ
ikalinin wrote:
Fri Nov 19, 2021 11:56 am
send me a pm.
I can't PM you "Some users couldn’t be added as they have disabled private message receipt."
SmyQ
Rogue One wrote:
Fri Nov 19, 2021 6:09 am
Just a heads up...
:facepalm:
Thank you
ikalinin
Oh. :/ ok, do it again. Just enabled it
rajesh1136
I see several of you tried. I moved from states to canada and my 2016 rogue displays in F. i dont mind but when i try to trade in , i fear it will fetch less offers in Canada.
So i explored and like other i bought a used canadian car part of auto ac unit and it still read in F.
where the AC AMP located ? i will try that as well.
rajesh1136
Hey do you still have the part ? or sold to other person ? and help me locate . where exactly it is ?
ikalinin
i still have the part.
rajesh1136
ikalinin wrote:
Wed Oct 19, 2022 8:15 am
im assuming it will fit for my 2016 Nissan rogue. VIN KNMAT2MV0GP686894. Can you share the part number from the canada spec ?
im in Ontario Canada but also have US shipping address. We can work it out. if you are interested.
update: looks like it wont fit https://parts.nissanusa.com/p/89578643/277609TG0D.html
rajesh1136
Help me locate the part in my car please.
I see a trim side to glove box that’s what I removed to change my radio.
That was the starting point.
VStar650CL
Technical Expert
There's a panel at the very front of the console near the passenger's left foot. Just pop it loose, the Auto Amp will be right there on the bottom of the HVAC housing.
ikalinin
you remove the trim on the pass side under the glovebox. its triangle shape
rajesh1136
thanks guys. i found it. for my 2016 rogue originally meant for USA is having part 277604BU0D. i have to hunt for canadian part now
rajesh1136
wondering cant we reprogram it to say Celcius or Fahrenheit ?
VStar650CL
Technical Expert
rajesh1136 wrote:
Wed Oct 19, 2022 9:29 am
No, it doesn't work that way. The Auto Amps aren't CAN-programmable, you need to get a different part.
rajesh1136
VStar650CL wrote:
Wed Oct 19, 2022 9:45 am
Thanks. Reason for my question. Check this out. Dealer in Canada.
https://parts.ajaxnissan.com/p/Nissan_2 ... .nissan.ca
Hvac Control Module
Part Number: 27760-6FL2C
Supersession(s): 27760-4BU0B; 27760-4BU0C; 27760-4BU0D; 277606FL2C
Supersessions have 27760-4BU0D which is my current part
VStar650CL
Technical Expert
I dunno. US-built models all show -4BU0C, -6FL0C, or -6FL2C. The -4BU0D doesn't show up at all. But we know from prior experience that the C/F display is definitely determined by the Auto Amp programming. I don't know what to tell you regarding the supersessions, maybe they're US-model typos.
rajesh1136
VStar650CL wrote:
Wed Oct 19, 2022 11:06 am
Thanks. im searching in used parts places lets see if i can find one.
Return to “Rogue Forum”
