Ok in terms of searching the forums I didn't like most of the answers given as they replaced the entire subunit, that being the Fan Amplifier on a whole for $60.00. This amplifier is Darlington Array NEC 2SD1297 and can be found at this website
http://www.cpcares.com/transistors/2SD1297.html under NTE Replacement part. Though the price of this part is about $20.00 this is the only expensive part of the actual Fan Amplifier once one is careful enough not to break the pcb poard while removing it from the interior of the "casing "or heat sink which is the large silver box everyone talks about. You can test the Darlington array by testing its hfe(current gain) with an electric tester and the voltage drop from the base of the transistor to the emitter which should be about 1.2V. So all in all if you are electrically inclined feel free to dig in if not pay the $60.00 for the entire sub-part. Will post Some pics if I get a digital camera any time soon.
As my great friend states: either way "Possible Minor loose , Major Win "
