SolaraOnBronze »
https://forums.nicoclub.com/solaraonbronze-u107872.html
Mon Oct 12, 2009 3:51 am
I like to think my tires are pretty decent... for sure better than a lot of things I could be running. And like I have said before, this car pretty much never sees the track... Since I have owned it, I have gone to the drag strip once, 0 autocrosses, 0 track days, and 0 track events. Considering that, I am happy with the mods I have chosen. You're right, I'm sure super stick tires would make the car handle better, but I don't really need it to at this point.
I have been meaning to update this anyway...
The car has been sitting for just over two weeks. It developed a misfire on the number 2 cylinder on the way home from a meet and was running on 3 cylinders. I replaced the spark plugs and tested the coils, but that didn't help, so I suspect a bad fuel injector. Since I have injectors waiting to drop in, I am probably just going to call it a summer and get to work on Winter Build Round 2.
This winter is mostly going to consist of maintenance and engine bay work. I am planning to pull the motor with the help of my cousin over his Thanksgiving break and get a few things done over the winter:
Paint engine bay- I am also going to fix the rust on the passenger side strut tower.
Clean up wiring- remove random/extra wiring and do a mild tuck- mostly just clean up poorly tapped and wrapped wiring and route things a little better.
Replace rubber lines- pretty much any rubber vac, coolant, or fuel line on the car is dry rotted and needs to be replaced, including the lines under the intake manifold.
Clutch/Flywheel- The previous owner doesn't remember what kind of clutch he put in the car, and the flywheel is stock. I am going to install a new clutch and flywheel to make sure everything is up to par for the new setup.
Motor mounts- Mine are pretty smoked and there is currently a lot of engine movement, so I am going to replace the trans and motor mounts.
Powdercoating- I am hoping to have a few things powdercoated in the bay to freshen things up. The main thing right now is my fuel rail, but I'm sure other things will pop up as well.
General maintenance- I hope to replace a lot of maintenance items, including intake and exhaust gaskets, coils, and other OEM wear items- perhaps water pump, oil pump, belts, front main seal, etc. Think reliability.
Install new goodies- My other reason for pulling the motor is to make the new goodies easier to install. These have already at home waiting to go on- here is what will be bolted up:
GReddy Intake ManifoldNISMO Clutch LineGReddy Airinx IntakeGT28 S15 TurboZ32 MAFApexi Power FCDeatschwerks 650cc InjectorsDIF Turbo Lines
If funds allow, I might do this stuff as well:
Aftermarket turbo manifoldNew downpipeNew catback exhaustNew wheel/tire setup (?)
Hopefully, by April the car will be back together and running like a top. I got a pretty good amount done last winter and I am hoping to do the same this year. Maybe this time it will come out of the garage a bit more reliable. I'll update this or start a new build thread for winter 09-10 when I get the car moved to storage and start working on it in the next couple of weeks.
