I picked up the cherry picker from my cousin late on Thursday night, and got to work on things for a bit. I ended up pulling the manifolds, alternator, power steering pump, and engine mounts/brackets off of the engine so that I could clean everything really well the next morning. Called it a night at about 2:30 AM or so.
I woke up and got started on the car at 7 AM on Friday so that I could make the most of my day off. I started by taking some Purple Power to the drivetrain to get everything as spotless as I could. It wasn't in terrible shape to begin with, but it cleaned up really nicely:
Before:
After:
After the engine was all cleaned up, I prepped the bay for the engine to go back in. I had to cut & flare the rear brake line for the Chase Bays kit, so I got that out of the way while it was still easy to access.
After that, I reassembled the engine and dropped it back into the car. I had a neighbor come over to help, but I wasn't really sure how to approach it at the time. I ended up letting him go since I felt bad using up a lot of his time, and installed it alone lol. Fortunately I was able to take my time, and I managed to install it without damaging the paint at all.
Before the engine went back in, I finished installing all of the brake lines on the driver's side, as well as the clutch and brake masters. This allowed me to toss the steering column back in, as well as the shifter assembly. Still a lot of mess to deal with in there...
While I was working, the UPS guy showed up with a care package from Mr.Broadfield himself- the last remaining components I needed to complete the battery relocation:
I ended the day by finishing the front suspension and installing the new front brakes. I was also able to install the Chase Bays power steering setup:
This was before I messed with the PS lines- they aren't sticking out on the tub like this anymore. Fits much better now!
So that was Friday... I didn't have much time over the weekend to touch the car other than that, because I was busy finishing up the nursery for the baby. I managed to work on it for an hour last night, but that was all I had the time for.
I started to run my engine harness into the bay, and ran into a bit of a snag. I was able to carefully run the harness through the hole I made in the trans tunnel for it, and everything reaches where it needs to on the engine with plenty of play to spare- so that's a good thing. However, I'm left with a MASSIVE pile of stuff in the interior and no place to put it. I sat and pondered this decision for a while, but arrived at only one easy and rather painless solution:
Ditch the HVAC system. Now I know I am going to get a lot of crap for this one, but hear me out. My car doesn't have AC, and the holes for the AC stuff in the firewall were welded shut when the bay was redone- so that's a done deal. As for the heat, my blower motor has not worked for some time. I don't know why, but I have essentially been driving the car without heat or the ability to turn the blower on for the past 2+ years.
I've tried to fix the blower motor on a couple of occasions, but haven't had any luck. After looking into the drawbacks of not having a heater core (besides the obvious lack of heat,) I don't see it being a major issue. The car is only driven in warm weather, and never sees temps below 40 degrees- not balmy by any means, but bearable. I'll probably be driving it less after the baby arrives anyway- so it seems like a logical sacrifice to make. I haven't had defrost in two years, and the engine has never overheated on me- or come close, for that matter.
In the end, I think it is the right decision. This frees up a TON of space for me to mount the fuse box, relays, brake bias adjuster, igniter, ECU, and all of the associated wiring that is now in the interior. In addition, it also cleans up the bay by removing the nasty mess of heater hoses and clamps required on the back side of the SR in a 240SX chassis. I think I will be happy with my decision- if not, I'll keep the components to reinstall them later and find another solution for the wiring.
I removed everything but the core itself- I've gotta drop the dash bar and remove that tonight if I get the time. Then I can start to tidy up and mount all of this stuff.
The engine harness is pulled into the bay- I'll probably hook that all up tonight as well to see how it looks:
