Q45tech »
https://forums.nicoclub.com/q45tech-u112.html
Tue Apr 27, 2004 4:52 pm
T3 had a custom one made back in 1998, they needed to send a old Q rad for fine shape tuning........mine went back twice because they had a hard time understanding that there was a plastic cover immediately atop the rad so the rad filler neck and added overflow cap stuck up too much to clear. Finally just cut a big square section ur of the plastic that way, I could check without removing plastic cover.
We tried to do an accurate AB against a new oem rad but time consumming to change back and forth burp the system etc.
My best guess is that the stablized idle is 4-6F less and the on road at speed is at least 5F less in 100F ambient.
The thermostat starts to open at 170F, tries to maintain 176F, and is fully open at 195F........obviously heat transfer into coolant is fast but thermostat reacts slower so you get overshoots [spikes] in temp...........180F [as seen buy ecu is great].
What one needs to do is get engine hot on highway and data log temp [with Consult 1F accuracy] vs time say every 15 seconds after you pull off.
See how many minutes of idling in gear with AC on before the temp rises to 195F then 200 then 205, then 210F.........220F.
Might as well data log [cheap[ radioshack outside digital therometer] the rise in AC center vent temp at the same time useful later.
