MADTECH »
https://forums.nicoclub.com/madtech-u18476.html
Fri Nov 26, 2004 11:32 pm
eagle rods arias pistons 0.5 od clevite77 bearings engine tilted straight for more space on exhaust side custom made plenum porsche 80mm throttle mechanical lifters original valves custom made camshafts turbonetics t70 turbo with custom made ex manifold in titan stabilised stainless steel(ss2337) 52mm stainless wastegate 4inch downpipe 3.25motoria exhaust big *** fmic custom made Autronic SM2,Autronic 4-channel 500R CDI ignition with original ignition coils(bosch) 1600cc injectors custom made cooling system with electrical waterpump 3 waterinlets on each side of the block and one on the back modded head gasket to supply water around all cylinders 40mm custom radiator water/oil heat exchager for oil cooling with dry sump Hydac 10microns abs glassfiber oilfilter generator switched to left side to get room for a mercery drysump pump sucking from modified original sump to external oiltank from that tank with original oilpump in to engine
