Not gonna cut it lol. You need 1, possibly 2 steps colder.BoostedNismoNJ wrote:NGK Race Spark Plugs w/7 heat range.
A buddy of mine landed a $22/hr job workin 7 12s, he spent the 6k he made in the couple month. on his s13, so hey, it can happen..srblacks131 wrote:This build will never happen...
Logan76 wrote:now you can go fast, can you stop fast also? A 600hp cardboard box is worthless
Hmmmm people really need to learn to readBoostedNismoNJ wrote:Thats it for performance im going to add suspension etc later.
My comprehension skills are just fine. Its just that I dont agree with you at all, you want a 600hp "daily driver" that is where you loose me. For that car to be streetable your going to want chassis bracing and big brakes, suspension can wait...but it shouldnt. You may be able to afford this, but I do care to tell you, that you should think it through before diving headlong into a 600hp mess. Best of luck to you though, I hope it all works out.BoostedNismoNJ wrote:
i really don't think 18psi is gonna give you 600hp bro, i'm guessing more like 30-35psi..i mean 600hp, that's the output of the new dodge viper. So if you're planning on only running 18psi, you really don't need the fuel pump that will support "over 700 rwhp" o and before you say that "i need to read the whole post" and you are not planning on putting out 600hp on the street, just 18psi, you did say that you want a 600hp daily driverBoostedNismoNJ wrote:Ok first of read the entire post i stated ill be running 18psi on the street second off the 850's are gone im going with the 95lb/hr injectors and the will support up to 608 hp so they will be fine 3rd off im not going with a 6 puck dont know why i posted that im going with a Z1 TT Street Clutch Kit to go with the 300zx transmission 4th i wont need dual 255s the 300zx pump will do finea new Stock Nissan OEM twin turbo fuel pump capable of delivering enough fuel to support over 700 rear wheel horsepower
lol he's saying that's he's only going to use about 18psi ON THE STREET.spooled240 wrote:
Logan76 wrote:Its just that I dont agree with you at all, you want a 600hp "daily driver" that is where you loose me. For that car to be streetable your going to want chassis bracing and big brakes, suspension can wait...but it shouldnt. You may be able to afford this, but I do care to tell you, that you should think it through before diving headlong into a 600hp mess. Best of luck to you though, I hope it all works out.
But it's supposed to be a 600 hp DAILY DRIVER! lol which is it gonna be?600 on the street would be retarded IMO, wayyyyyyyy too much power not enough everything elseS13CoupeLover wrote:
this boy has 600hp, look at the flames off his tiresLogan76 wrote:A 600hp cardboard box is worthless...
