Wouldn't be the first time I was mistaken but I was pretty certain poncams required lifters.jdmser wrote:Yeah, I think that's backwards. Some procams need solid lifters and all the poncams are straight drop in.
OP-If your doing a custom dump why spend the money on the Greddy downpipe. Have the whole thing done as one custom piece to the cat.
The thing with deatschwerks injectors is that you NEED to compensate for the injector lag because the lag curves they experience are wayy different than the stock injectors. I first installed my 650s without changing the lag settings and the engine ran pretty rough and idled like crap (hunted, sputtered off-throttle, etc.) I changed the injector lag settings and it purred like a kitten. Just had to readjust the idle AFR after doing that.MATTs14 wrote:Yea after i posted that up I started thinkin that the 550s might be a little small. I considered doing deatschwerks injectors but ive heard mixed reviews on them.
No real gains, but i don't think you'll find any major gains with the splitfires for the money you'll be shelling out for them.MATTs14 wrote:I saw a guy running the msd ignition setup and it looked pretty good. Do these setups yield any noticeable gains or improvement over the splitfires? Thanks again for all the response and help.
He does not need to get into the motor that far to run 400 hp safely. Rods are not necesary, the factory ones hold up just fine with some arp hardware. The pistons are the weak point of these motors and even those have been pushed pretty far with good tuning.nismo_gts4 wrote:All that will give u 400hp, it just depends on how long the motor will handle it with stock internals. If you put aftermarkets rods and pistons in you can get some good hp since it has a iron block.
ALL Tomei Poncams for the RB20 are for hydraulic lifters only. The Procams come in both hydraulic and solid lifter applications.http://www.tomei-p.co.jp/_2003....html
Hey Matt, have you seen this? zerothread?id=352686MATTs14 wrote:Also i'll be using an xtd stage 3 clutch since it came with the new motor im building.
