400whp RB20 Build
Coolwhip
Vendor
Car: RB26 Raw Brokerage War Machine
Carl can knock out 750's without a problem. Believe he should have a rock solid tune for them (well atleast 720's or so). Go 750 :P just so when you get tired of 400 you're not upgrading again.
You have a few options around that way for the clutch, all depends what you are looking for.
MATTs14
Car: Red 1995 Nissan 240sx
Thanks man. I'll do that with the 750's. I think i'll just hold on to the clutch i have in the transmission now. It feels great and it doesnt slip at all. If it becomes a problem which im sure it will then i'll upgrade it. I thought carl h was running an xtd clutch though??? Can anyone comment on this??
onepuff
How much horsepower do you have right now? Have you been in a 400 horsepower S14?
MATTs14
I know I know but i have driven a 400 horsepower car. My buddy has a nearly 450 horsepower supra and im not a terrible driver. I know mine and the cars limits. Im comfortable with having 400 and im ready for it.
Carl H
i had an xtd clutch intially when they first came out, but back then they were exedy HD pressure plates and clutch net discs...they have since changed manufactuers.I run a spec stage 3 clutch on my car with no ill effects...have done so for the past 2.5 years now give or take.as far as hp goes 740's are more than enough fuel for what you want and will give you head room to work with; my 720s are only at 74% duty at 22psi...so i could potentialy squeeze close to 30psi out of the turbo before fuel would run out.also comparing a 450whp supra to a 450whp s14 is apples to oranges, the supra has a good 1klbs on the s14 and when you're talking about that large of a weight difference i can tell you that the s14 will be loads faster.I hope you have a good lsd and suspension setup because you'll be all over the road otherwise...my s14 is setup to the point where i dont loose traction when boost hits but you sure as hell better be able to keep it in a straight line as it pulls like a cut bastard.
MATTs14
Yea i believe that. I'm prepared though. What do you guys suggest for the bare minimum on suspension mods. I dont want a hardcore track setup since i live on backroads in tennessee which means hills and potholes and some rough ride conditions and i dont feel like blowing out some good coilovers in a year. Should i get coilovers? Traction rods? Tension rods? Im not a suspension guru AT ALL so any help is good
Also you said you could push 30 psi on the 720s. How much boost do you think i'll have to run to get the ol' diesel turbo (HX35) to give me 400hp??
And Carl H if you dont mind me asking, how much power are you making now???
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
MATTs14 wrote:Thanks man. I'll do that with the 750's. I think i'll just hold on to the clutch i have in the transmission now. It feels great and it doesnt slip at all. If it becomes a problem which im sure it will then i'll upgrade it. I thought carl h was running an xtd clutch though??? Can anyone comment on this??
750cc injectors HA! I say. Grab some 800cc's and you won't ever worry untill you need more hp....
MATTs14
Who do you recommend getting those from?
Yellow4g63
MATTs14 wrote:Who do you recommend getting those from?
I got mine from RHDJapan a long time ago. They are the Sard 800cc top feed low impedance injectors. I think they have a high impedance top feed now. Sard,Greddy,HKS ect they all use Denso injectors and throw there names on it. The Part numbers are denso. http://www.sardracing.com/products/Injectors.htm
Cjmartz2k
Car: Hunting for a '89 GTR now
MATTs14 wrote:Also you said you could push 30 psi on the 720s. How much boost do you think i'll have to run to get the ol' diesel turbo (HX35) to give me 400hp???
Certainly not 30psi. I'd guess like 1.2-1.3 bar.
Carl H
i was close to 400whp on a dynodynamics setup at 18psi...around 390whp at that time.engine has since been rebuilt, retuned and runs more boost so i'd guess around 415-425whp now at 22psi.
MATTs14
Thats pretty impressive!! I think you should take some vids of it. Ive seen all the old ones but i would love to see some new ones.
So what suspension mods do you guys suggest??
So far ive learned that i need the deatschwerks 750's, a much better clutch, and some suspension work. Im thinking of getting some drag radials too
So feel free to chime in and give any tips and pointers you can.
Id love to get some more opinions on a clutch and suspension. Thanks guys
Coolwhip
Vendor
suspension setup depends on what application of driving you'll be doing. Kind depends on budget.
MATTs14
I just need enough to keep me from being all over the road like carl h said lol.
Coolwhip
Vendor
then tires should be listed in the TO DO list as well.
Tires, Diff, and the struts & springs or coilovers of choice once again depending on how you drive.
Adjustable arms are always nice when getting into this mess.
Carl H
on my personal car this is what i have:nismo power braceST sways front and rearEnergy suspension bushings all around in all armsnew balljoints up frontspl parts solid differential mountsspl parts solid subframe mountseibach prokittokico dspec shockscusco strut tower bars f&rtein front camber platesats deftforce 2-way differentialr33 gts-t automatic final drive (4.36)
car handles phenominally, most people who ride in the car ask what coilovers i have and how i have them setup and they are shocked to find i have a spring and shock setup.it feels great, drives amazingly well and is great fun to drive.
MATTs14
Thats a pretty intense list youve got there. I looked at the dspec once upon a time but wasnt sure they would be great but i take it they are. Can you adjust ride height with those??
Carl H
no, ride hight is set by the springs...i am quite happy with the drop the eibach kit gives and it handles well...not much more to say.
no comments about the wing...its factory oem nissan aero believe it or not; fully adjustable and you dont want to know how much it cost.
MATTs14
wow carl the car looks great. The last pics i saw of it were when it was blue emerald or the other green lol. I think i might get some kts low coilovers and some sway bars and the power brace. That should be a good setup for a daily driver.
So does anybody have any comments on a preferred clutch?? I think its the last thing on the list for now
MATTs14
Well i thought id post up a little bit of an update for anybody that cares lol.
Im gonna be beefing up the bottom end a little with:
ARP Rod BoltsARP Head StudsCometic MLS Headgasket
I considered doing bearings but the motor is in good shape so i'll hold off for now.
Also im gonna be running a spec stage 3 clutch since theyre relatively inexpensive.
I got my synapse wastegate in the mail the other day and this thing is pretty impressive. I cant wait to test this thing out!
Also the innovate lc1 showed up so i can finally know whats going on with my motor.
Well if anybody has any input feel free to post it up. I like hearing what you guys have to say about it, unless its bad lol. Have a nice day
Carl H
hope you have some amazing way of getting the head decked better than 40RA for the cometic.
MATTs14
What do you mean by that??? WHich one should i use then if i dont use that one??
Carl H
im all about some stock hg to hold power.i run 22psi thru my engine and its a stock hg and arp bolts.just make sure you go thru and retorque the bolts after about 100mi of driving.
MATTs14
Well thats good to know. The motor had already had a headgasket put on it but im gonna go in and do arp hardware everywhere. What else do you guys suggest doing?? How much power will the stock pistons hold??
MATTs14
Well ive got almost everything figured out and all i need is a tune asap. I tried emailing carl numerous times and got nothing so...i tried a thread and it got shut down so just waiting on that.
Coolwhip
Vendor
it's school time. Give it time.
dsrturbo.com
Car: nissan
Does America use Links over there?? Like the new G4 fricken populer in NZ or ems
rb180
Car: 1991 240sx
looks good man
MATTs14
Thanks. I cant to wait to get this thing goin. Im ordering my injectors and bov tonight. Then i'll be ordering the arp rod bolts and head studs and clutch shortly after. How well will the stock pistons hold up with my power goals??
DriftingisLame
Car: '91 240sx coupe, rb20det
They'll hold up fine as long as you dont run lean, or detonate. The stock pistons are burl, but they're only as good as your tune.
