evildky »
https://forums.nicoclub.com/evildky-u13100.html
Tue Jan 13, 2009 8:48 pm
welcome to nico braap!for those not familar with braap he does amazing things with the L6 heads and did some great documentation of the megasquirt n edis, very knowledgable and technical person to have around
as for what I made on my cars, the Z32... I shorted the stock shifter, oterwise just bolting things on, and yeah I don't love the mellon shooter tips ont he hks exhaust, but it uses one less bend than every other system and uses a straight through muffeler which is a good thing for a turbo car
my 240Z, well I built the megasquirt n spark engine managment system, harness etc, I was runing a fuel rail I made before upgradign to the pallnet rail when I switched to o-rign injectors, I fabbeed a custom downpipe and full exhaust form mandrel bends, I sectioned my strut housings to accept shorter inserts and coil overs, I spuppose everyhitng else was bolt on or weld on, and I only killed that cone in self defence, it was trying to get me
my Z31 I fabbed some engine mounts form hockey pucks as well and the megasquirt n spark, downpipe and exhaust (this downpipe was a huge PITA, the stock turbo has a cast dp to go around the steering column, fabbing it was a bit tricky
I'd much rather build and tune my own engine managment than try tuning a carb, me a carb's just don't get along, and the stock electronic's on the L28ET are just uugly, my version looks much better
