jbona »
https://forums.nicoclub.com/jbona-u121380.html
Tue Jan 13, 2009 2:16 pm
this is all im saying to everyone interested in a v8 swap. you can get a Gen I or II and put out monster numbers for a reasonable price (my father is putting 600hp/540ft-lbs for $10,000, and that is with all BRAND NEW race parts), or you can go out and get a Gen III/IV LSx and put out the same numbers as a stock TT with a couple bolt ons. The other option to that is to get the LS7 for probably $15,000, and STILL not put out the numbers that the Gen I or II can put out for less money.What you do with your car depends on a few variables1) How much power do you want? Gen I/II will put out more power than Gen III/IV, and it is also easier to tune due to not being electronically controlled.2) How important is it to you to keep from cutting the hood, or would you be fine with having a nice scoop molded on over your filter? I like the lines of the Z32, but I also like the look of a nice scoop on the hood. A Mustang Mach 1 shaker scoop would look amazing on the Z, and it would look even better if you had 550+hp underneath it.3) How good are you with fabrication? There is quite a bit of fabrication needed for the swap, and if you can't do it yourself, be prepared to pay someone some good $$ to do it.4) How deep are your pockets? Like I said, it will cost you a pretty penny for the fabrication if you pay someone to do it. If you can do the fab yourself, then you will have more $$ to put into making bigger numbers.
Basically, if you care more about the IDEA of a V8 in your Z than the POWER of a V8, then go find yourself a junkyard 350 and slap it in there. If you want the power, then do a Gen I/II and do it right, and then enjoy going fast, quick.
