2nd gen Rogue's bulb replacement / LED upgrade
Leo2005
There's plenty of pictures on this forum about '08-'13 Rogue leds, hids, headlight mods etc. but not a single pic about '14. So post your upgrades/mods in this thread and others can confirm the bulb size in specific location before modding on their own. Here's the start for interior rear lights above the rear doors...the bulb is 194 which is common:
Reason: Revised title
chunkay206
Car: 2014 Nissan Rogue
so my first mod i'm planing to do led everything inside. i have most led lighting for cargo, 2nd row lights all i need is the person lights = P1Y and vanity lights which i checked the manual and they have no bulb reference
has anyone have bulbs for P1Y and Vanity lights?
hawki
Car: 2015 Rogue SL Premium
Red / Almond
If you take out the stock bulbs, the bulb model number should be in-scripted on the base/bottom metal part. Then search the model number on google/ebay and may find the more generic/common name/number for the bulb.
darcor7
Car: 2010 Nissan Rogue
those are for the 2013 i dont if there are the same in the 2014, Dome Light DE3175, Map Light Bulb175. I use the same in mine i have a 2010
zengshengliu
Car: 2008 Nissan Rogue SL
http://www.vleds.com/shop-bulb-numbers/vanity-led.html
This is probably the vanity light you are looking for, but check the picture to make sure
as for P1Y, I have no idea
Leo2005
Item Bulb No.
High H3
Low H11
Park W5W
Turn WY21W
Sidemarker WY5W
Front fog lights H11
Daytime running lights (Canada only) PS19W
Map light* LED
Footwell light 158
Personal lights P1Y
Glove box light 158
Step light 194
Courtesy light N/A
Vanity mirror light N/A
Cargo light AL1X
High-mounted stop light LED
Tail/Stop 7443
Turn WY21W
Rear sidemarker W5W
Backup (reversing) W16W
License plate light W5W
Leo2005
For vanity mirrors - vanity leds from vleds.com work great but I wish I could get slightly dimmer because these are a little bit too bright for the sunvisors. Even with pure with 5k color it's still blinding me a little:
Got V3 Triton for turn signals and could not fit them at all at tail lights (not enough space between tail lamp and the body) but I was able to fit them in front headlights as 7440 bulb and that was PITA as installation but the resistor is included so no cutting wires at all this time. Picture is not that great due to sun reflection but trust me it is a lot brighter than the stock bulb pretty much just like you see on the picture:
Ordered Morimoto H11 for the low beam lights but one ballast arrived defective. Waiting for replacement:
Qashqai
Leo2005 wrote: Image
Can you rotate the LED bulb 90 or 180 degrees? It will decrease the light output and will not cause glare. Don't worry, they won't emit infrared (heat), so by pointing the yellow phosphor part (emitting surface) towards the plastic will not melt anything.
Leo2005
Qashqai wrote:Can you rotate the LED bulb 90 or 180 degrees? It will decrease the light output and will not cause glare. Don't worry, they won't emit infrared (heat), so by pointing the yellow phosphor part (emitting surface) towards the plastic will not melt anything.
Good point. Thanks.
iRogue
Car: 2014 Nissan Rogue SL AWD + Premium Package
What type of bulb used for vanity lights?
Leo2005
iRogue wrote:What type of bulb used for vanity lights?
I used these: http://www.vleds.com/shop-bulb-numbers/vanity-led.html
I couldn't find any led bulbs for the trunk. All of them are too big but this...looks like a joke even during the night. It provides less light than my previous '08 Rogue:
So I have used the led circuit with squeezed all the way 3175 adapter:
Much better. Even the camera gives a blur picture because of the brightness:
yi_dennis
Car: 2014 Rogue SL
The position of the trunk light is horrible. I was hoping to find just a replacement bulb.
Leo2005
yi_dennis wrote:The position of the trunk light is horrible. I was hoping to find just a replacement bulb.
Yes I totally agree with you. As for the replacement bulb the closest bulb to the size is vanity bulb for mirror as stated above. It is slightly bigger so you would have to push to contacts away from each other further and vanity bulb doesn't have pins on the side so it's not going to sit tight in the contacts you will have to make some kind of brackets or glue it (use your imagination) in order to keep them in place. Plus on top of it the circuit board provides more light anyway and it is pretty easy to install. Go for it...it's worth it.
P.S. On the picture the led is installed the wrong way and doesn't light up. You have to flip the adapter in order to work.
yi_dennis
Car: 2014 Rogue SL
Thanks for the suggestion. Its bit more technical than I want to attempt. I guess I will wait and see if someone comes up with a new bulb.
Leo2005
http://www.vleds.comoffers only today a discount of 20% on the entire order. If anyone wants to upgrade the lights it is a great deal. Just ordered HB3(9005) LED bulb http://www.vleds.com/headlights/led-hea ... k-cxa.html for my high beam and 7443CK Red for my stop/running lights http://www.vleds.com/shop-bulb-numbers/ ... 1-red.html
daltonvol
Car: 2014 Rogue SL (Premium Pkg)
Traded - 2013 Rogue SV (SL Package)
2011 Maxima S
Hey Leo, I want to replace the dome lights above the rear seats...I've looked at the site you recommended and also done a general search. Needless to say, there are a multitude to choose from. How specific do I need to be when replacing these (i.e. will any 194-type bulb fit or do I need to find something more specific to the Rogue)? I've seen a lot that have the bulbs on the end, like the ones you pictured above, some that have bulbs around the outer perimeter of the fixture, some that have both...are all these OK?
Leo2005
Pretty much any 194 bulb will work. The more expensive ones will give you more output.
daltonvol
2011 Maxima S
Gotcha! And it doesn't matter how many watts (i.e. I'm not going to catch my interior roof on fire!)? Thanks for the feedback!
Leo2005
No.
JB'sTitanXD
Car: 2017 Titan XD Cummins
Have any night shots of the Morimoto H11 against a wall or garage? Interested in the light pattern. I also thought the 14s took 9005 bulbs.
Leo2005
I got my replacement yesterday and got it installed this morning. Will do the shot tonight against the wall.
JB'sTitanXD
cool thanks! I think i might run some of the LED headlight bulb made by Lifetime. Had them in my truck and loved them.
JLD94
Car: 2014 Nissan Rogue S Moonlight White
ha ha, just saw this thread, I asked about this in another thread. :chuckle:
iRogue
Is it me or the Rogue doesn't have a glove compartment light? I looked through the manual and it appears as if there should be one.
Leo2005
iRogue wrote:Is it me or the Rogue doesn't have a glove compartment light? I looked through the manual and it appears as if there should be one.
I was about to b**** about it the other day but when I came to the dealership they told me it is applied to SL models only. Now I see yours is SL and you don't have it either. Not sure how luxury the extra bulb in the car but my fiance doesn't have it either in her 2014 Corolla. So when it gets warmer I will install the light in both cars. I do see a hole which looks like is for the bulb in the Rogue's glove box btw.
JB'sTitanXD
My SL doesnt have it either.
iRogue
This is absurd! Does anyone know if there's a kit or something available to retrofit a bulb into the compartment?
-- Side note- the 5k vanity led bulbs are too bright and make it difficult to look into the mirror.
Leo2005
iRogue wrote:This is absurd! Does anyone know if there's a kit or something available to retrofit a bulb into the compartment?
There's no kit available but all you need is a small switch (similar to hood pin) preferably with plastic pin and 2 wires. You'll run one positive wire to the constant source like battery, cigarette lighter etc. and negative wire throw that pin. Add any bulb you like and stick it on top of the box. Here's an example of adding led circuit board in glove box:
http://www.nicoclub.com/archives/how-to ... rogue.html
Leo2005
JB'sRogue wrote:Have any night shots of the Morimoto H11 against a wall or garage? Interested in the light pattern.
JB'sTitanXD
looks good! what mods were required to run the H11?
Return to “Rogue Forum”
