2nd gen Rogue's bulb replacement / LED upgrade
Leo2005
tsumeone wrote:I'm a bit confused at the mention of dome lights. In my 2014 Rogue SV, there is only one dome light. Is this because I don't have a moonroof?
That's correct. I fount out it too 2 days ago at my girl's rogue.
tsumeone wrote:Does it take the same type of bulb as listed in this thread?
Probably not. To make sure remove the cover and take a look what bulb is in there. My guess it's the same bulb as in 08-13 Rogue which is DE3175 31mm.
tsumeone
Car: n/a
I popped it out and measured it with my digital calipers. It came out to 30.6mm, so you are probably right on the money.
Edit: Be really careful if you have this setup. My bulb popped up into the ceiling, rolled away, and now it's gone forever. No way to remove that plastic thing either. Really stupid design Nissan.
Ferrisfan
Car: 2014 Rogue SL FWD w/ Premium Package
tsumeone wrote:I'm a bit confused at the mention of dome lights. In my 2014 Rogue SV, there is only one dome light. Is this because I don't have a moonroof? Does it take the same type of bulb as listed in this thread?
The moonroof equipped vehicles have 2 interior lights that take #168 lamps.
JB'sTitanXD
Car: 2017 Titan XD Cummins
Jatlfan wrote:VLED H11 5K 2100 lumen upgrade on my 2014 Rogue SV
How come most of your light is projected on the ground in front of you?
tsumeone
Car: n/a
At Ferrisfan's recommendation, I purchased this bulb for my cargo area: http://www.amazon.com/gp/product/B009NO ... UTF8&psc=1 I also purchased the same bulb for my dome light (on the non-moonroof Rogue, this bulb basically the same size as the stock bulb there). Made a noticeably positive difference in lighting. And they do sorta fade on and off when you lock/unlock the car like the stock bulb did, but not as noticeably. If someone wants to upgrade their interior lighting on the cheap, that's the bulb I'd go for.
zengshengliu
Car: 2008 Nissan Rogue SL
JB'sRogue wrote: How come most of your light is projected on the ground in front of you?
Its the camera. You can see the light at the curb too
The camera adjust to the bright spot closest to the car, so all the light behind is "gone"
elmodeer
Car: Nissan Rogue 2014
Hi all,
Would it be possible if someone volunteers and list the bulb sizes for reverse, parking, high and low headlights, fog lights and also list the LED replacement bulb/kit for each? A link where to purchase and some photos will be greatly appreciated. Thanks in advance
sideshot
Car: silver 2014 nissan rogue sl awd
Anyone try these https://www.lifetimeledlights.com/led_l ... 11_35_watt
$219.00 there 6500k vs 5000k for $150.00
Leo2005
I have a set of oem led headlights at home. I modified the harness to try with power supply for 12V+ and it works but there's a lot more involved in order to keep it working in the same condition. I think I'll go with plug-n-play led bulbs but I would like to have the same brightness as hid. Hard for me to choose at this point. V-LEDS is about to start selling 3000lm with 2 leds/bulb (1 on each side) for equal light output at the headlight. Lifetime leds offer 3200lm but with 1 led. Anyone found led bulb for H9(High Beam) yet?
8102
Car: 2014 Nissan Rogue SL
I just installed the H11 F LED Fog Lights (5000K) on my 2014 Rogue to replace the stock fog light bulbs, so far, so good, they look good, match the color of the stock LEDs Headlights pretty good and look like they are very well made.
8102
Hi,
As anyone used the AMBER AMBER V3 TRITON LED SYSTEM (Part ID: V3_AA-Crom) from http://www.vleds.com for the Front Amber Turn Signals in the 2014 Rogue?
Just got mine delivered and they look like they are going to be tight to install.
Leo2005
It will be tight but it's worth it
Ferrisfan
8102 wrote:Anyone try these https://www.lifetimeledlights.com/led_l ... 11_35_watt
Do they actually add more light in bad weather conditions? $150 is more than I want to spend for cosmetic lighting.
elmodeer
Would you please send a link for this kit? Also, can you share a picture how you mounted the kit driver? Thanks in advance for your help.
8102
I think they do "fill in" the Light Pattern nicely and are worth it.
I ordered my Rogue with OEM LED Headlights and am totally impressed, I will never go back to Halogen or HID, the LED's are awesome and the addition of the LED Fogs just makes it that much better.
Good Luck with your decision.
thecmancan
Car: Nissan Rogue 2014 SV w/ Family PKG
I got these http://www.ebay.com/itm/261455749240?_t ... EBIDX%3AIT
How do I pop open the Map Light?
tsumeone
Car: n/a
The 2014 Rogue is different than the 2008-2013 Rogues and 2014 Rogue select. They used the wrong rogue in their advertisement picture on eBay. If you look at the pictures in that listing, the interior is totally different. If you have a 2014 rogue, those bulbs probably won't fit. The map lights in the 2014 rogue look a lot different and are already LEDs.
TaoLao
Like what tsumeone said, the maps is a lot different and already LEDs in the '14 Rogue. It just looks warmer. I've already tried to disassemble the map light to see if I could replace it but the LEDs are actually permanently mounted on a circuit board. If you know how to solder you could possibly change it.
thecmancan
Crap. Well I take the most issue with the poor trunk lighting.
So I'll be trying to change out the dome light on the 2nd row and the trunk light.
Thanks for the answers!
8102
Has anyone upgraded the rear red sidemarkers with the 194 RED 6 LED HIGH POWER 360°LEDs from www.VLEDS.com
I was upgrading the Turn Signals, Brake Lights, and Licence Plate Lights and wondered if I should do these at the same time because they are right there.
Thanks
Leo2005
I tried ones from dome light and they were too big. Do you really think they would make a difference? Pointless in my opinion.
outtolearn88
Car: Rogue SL AWD
Hello Everyone, Can anyone share any info on how to get access, as to replace the bulb of the fog lights ? Would greatly appreciate the help on how to. Thanks ;)
Reason: Merged with existing thread
nismomaxgtr18
Car: 1998 Nissan Maxima SE
2014 Nissan Rogue SV AWD
Chemalito wrote:So the trunk LED shuts down after a while(its maybe 2 minutes or more, wich is not normal I guess) If anybody else has this issue let me know, or if this is normal with that LED upgrade too!
I just installed a small LED board into my cargo light. They are so bright!! But, I am having this issue as well. When I close the hatch, the LED stays on extremely dimly. It stays on for at least 2-3 minutes before turning off.
Also, I somehow managed to knock that gray plastic cover that snaps onto the clear lense off and it feel inside, behind the trunk wall. Does anybody know the best way I can retrieve it?
Koushtj
Car: 2014 Rogue SL AWD
outtolearn88 wrote:Hello Everyone, Can anyone share any info on how to get access, as to replace the bulb of the fog lights ? Would greatly appreciate the help on how to. Thanks ;)
I'm also interested in this? Not crazy about the regular fog lights specially since I have the OEM Led low beams. Also what exactly are the parking lights(side markets) in the rear?
Leo2005
Pop the plastic trim on fender. Remove the screw. Pull the bumper and you'll have an access to the the bulb. Just did mine 3 days ago for vled 3000 lumens.
psyman42
Car: 2001 Honda Accord EX (Totaled)
2007 Honda CRV EX (Traded In)
2014 Nissan Rogue SV Premium Package (Sold)
2017 Nissan Rogue SL Platinum Reserve Premium Package
Hi all, I have a 2014 ROGUE SV with stock headlights and floodlights. I wanna upgrade these to brighter better lights, any recommendations/links?
Leo2005
Changed mine last monday for vleds:
psyman42
Leo2005 wrote:Changed mine last monday for vleds:
NICE! the dimmer foglight on the left, is that stock foglights? Also can you post which VLED you purchased?
Also I saw on this thread you bought headlights as well, can you post a link to those as well? Much appreciated! I feel the stock bulbs don't show much light as there were numerous times I had to check myself to make sure the headlights were on :wtf2:
8102
Hi all,
I had swapped out my OEM Halogen Fog Light Bulbs with Lifetime H11F LED Fog Lights in the summer.
Now that it is raining they are leaking so badly - standing water in the housings - that I took the my Rogue to a Auto Body Repair Shop to have the Fog Light Assemblies removed and dried and the bulbs re-installed (In case I had installed them in-correctly in the first place).
Well, it turns out the Lifetime LEDs do not fit tightly into the Fog Light Assembly and that is why they were leaking, so the OEM Halogen Bulbs have been re-installed.
It could be something as simple has the wrong rubber gasket - don't know yet - but I have a call into Lifetime to see what is going on.
I am wondering if anyone else has had moisture problems with Lifetime or VLEDS Led upgrades for the fog lights?
Thanks
Leo2005
psyman42 wrote:NICE! the dimmer foglight on the left, is that stock foglights?
Yes.
psyman42 wrote:Also can you post which VLED you purchased?
http://www.vleds.com/shop-bulb-numbers/h11-vx3.html6,000K bluish is the one I installed (I still think it's kinda white)
http://www.vleds.com/h11-mtg2-3000lm.html and here's the 5,000K if you want pure white.
psyman42 wrote:Also I saw on this thread you bought headlights as well, can you post a link to those as well? Much appreciated!
EBAY
8102 wrote:I am wondering if anyone else has had moisture problems with Lifetime or VLEDS Led upgrades for the fog lights?
I don't have a problem with v-leds bulbs but you shouldn't have any problems with other brands either. I think you got defective set. If I was you I would give them another chance. Return and get a brand new set but if second set is leaking as well then return them. Also the socket is H11 and I have no idea what is the difference to H11-F so that might be the case.
Return to “Rogue Forum”
