blackieblack wrote:i hear alot of well defended points about the 2J. no **** its a power house. that not whats being debated. if we were to put a lets say an RB and 2J with the same horse power range then the rb is over all a better performing motor. this may be about dyno queen numbers for some of you out there or just quarter mile performance. if we were talking about the best motor for the 240. and i mean OVERALL. it definately wouldnt be the 2J. guys just cause you prefer the 2J doesnt mean its the best motor. maybe on the dragstrip. but i would bet my money on a fully built 350 over a fully built 2J on the strip in a 240sx. theres been a bounce around between the 2j and the rb for awhile. if had the money to blow on a rb or 2j. i wouldnt buy either. i would buy a vq35de and boost it. lighter than booth aforementioned engines and has better weight distribution. horsepower gains can be had on stock internals. and the next gtr will be using a vq engine similar to the 35de. its better than the rb in a 240 and byfar better than a 2J.
Well saying an RB will out perform a 2JZ is wrong. People say that because the RB revs higher and gives you a more useable power band, but when racing when are you ever at 2000rpm?
An RB vs JZ with same HP#s is up to the driver.A 4WD Skyline +(More handleing computers then IBMs database) will no dout beat the pig Supra. But RB beat a 2JZ... thats a much tougher debate.
And weight wise the RB isnt much lighter, I have read the it weights more then the 2JZ. (not sure if its tru but based on displacement I will give the RB the benifit of the dout)
A VQ lighter... NO dout! Better weight distribution... Yes!Horsepower made on stock internals... what ever that means. A honda can make HP with stock internals. Run 8psi on either Civic or 350z and see what happens. In the mean time try to learn how to take apart a VQ engine. Chances are you will have a month before **** hits the fan.
In order to make serious power in a VQ, you need to do some serious work! Now I am not saying they dont make power but if me (and my 2jz) and you (with your VQ) had a buget of $8k...I would cruise by you.This shows you how to boost the VQ right the first time.
*Please note the prices*
zerothread/105250
And the only thing thats similar to the VQ35 in the Z and the VQ37 thats in the GTR is the first two letters. The GTR will be running boost so chances are there not gunna use the 11:1 Z33 compression. Plus I dout they will be using similar internals. The GTR motor will probably be a fully built VQ.
And the last statement grinds my gears.
blackieblack wrote:its better than the rb in a 240 and byfar better than a 2J.
Because you dont specify in what means its better. If you said its the better motor if its left stock. Then yes I agree.
If you want to say its better boosted. I will slap youIf you want to say its better overall potential. I would agree.If you want to say its better on a (normal) buget, I would slap you twice.
So what did we learn here today. BE MORE SPECIFIC and dont throw out generic opinons unless you have some thing to back them up with.
PS - Best motor to install for 400-550Hp would be the good ole' fasion LS(1/2/6/7)
