Nice graph - I went the source page and thought it would be worthwhile posting what curves A, B, C, and D are. The posting said:BobE wrote:I just did some reading (per Ur suggestion) and I like this article a lot!
http://www.lubedev.com/smartgas/additive.htm
Their curves show mpg increasing up to just over 3oz / 10gal and by 6oz it's a decrease.
Shown is the percentage MILEAGE GAIN when a tiny amount of acetone is added to fuel. The curves A B C show the effect on three different cars using different gasolines. Some engines respond better than others to acetone. It is important to use the same gasoline from the same gas station when testing mileage otherwise you have too many variables and get undependable results. The D curve is for diesel fuel. Too much acetone will decrease mileage slightly due to adding too much octane to the fuel. Too much also upsets the mixture ratio because acetone (like alcohol) is a light molecule. Acetone helps the fuel become a vapor more easily inside the chamber and minimizes wasted fuel. All it does is offer total combustion of fuel in any kind of engine. The A curve is with a 1995 Neon. The B curve is with a 1986 GMC. The C curve is with two Caravans, 1990 and 1997.
