numbnuts240 »
https://forums.nicoclub.com/numbnuts240-u42843.html
Mon Nov 16, 2009 3:46 am
update: got the new cam cap bolts in. installed another 248 cam. fired it up it ran like it should with that cam combo. there was some noise coming from the front of the valve cover that sounded like the noise that's described when the chain is slapping the guide. there was also some smoke coming from the egr tube area. the next day i took the vc back off, as well as the upper timing chain cover and removed both guides. i also found that the tensioner was not moving as freely as it should, so i loosened that up as well as the lower chain tensioner. got it all back together and the noise was gone. after idling for some time, the smoke also stopped (i'm thinking i might have just dropped some rtv on the exhaust and it was just burning off). took the car for a drive, it pulls nice and the idle is pretty cool sounding.
cel is on, i borrowed a code reader and i'm getting, iirc, p0340 and p0350. idk if those code numbers are right, but they were for the cam position sensor and knock sensor. i'm thinking they might be there from when the first cam broke but i wanted to see what you guys thought before i just erased them and went on with life.
oh, also did a compression test before firing it up the first time just to be sure. i have them written down at home so i don't remember which reading went with which cylinder, but i got 205, 210, 215, and 215. i'm sure the 205 would have been higher had i cranked it a little bit longer. also, these numbers were done when the engine was cold.
Modified by numbnuts240 at 5:56 AM 11/16/2009
