248/232 cam problem
krash
numbnuts240 wrote:at around 2500-3k is when it gets nice and it pulls for a while.
NismoZRS
Car: 92 S13 Coupe
"pulls for a while" doesnt exactly explain when it dumps off.. does it dump before or after 5.5k revs?
Modified by NismoZRS at 3:43 PM 3/2/2010
krash
numbnuts240 wrote: it definitely doesn't last until 5k.
Rauland-S13
Car: 1989 Nissan 240SX Coupe
[QUOTE=krash][/QUOTE]this was in refernece to the issue of power leg in the lower RPM range, not when it loses power in the upper range. would be interested in knowing just what the approx. power band is. pulling in the 2500 range would be a lot more fun that getting that pull in the 3200 range
numbnuts240
1974 Datsun Fairlady-Z 250GT
2011 Ford Focus
2010 Mazda 3
starts pulling around 2500 and then around 5000-5500 it starts to fall on it's face.
Razi wrote:i wish I could find S14s at my junkyard to take this cam off of.
i still have my stock intake cam...
breadbox
Car: 89 Nissan 240SX
89 Koop
84 720 4x4KC
numbnuts240 wrote:maybe i can do something cool with the l26.
Bore out the cylinders and store wine in it.
numbnuts240
2011 Ford Focus
2010 Mazda 3
you're a genius.
Dittoz7
Car: 1997 2f0WtY SE!
Does This Raise Hp Numbers In Anyways?
Or Just Kind Shifts The Power band?
SxMachine
Car: Im on a horse
numbnuts240 wrote:dude, that was it. i can't believe i didn't notice those things climbing in. here, i got you a present to show my thanks
http://img.photobucket.com/alb...n.jpg
numbnuts240
2011 Ford Focus
2010 Mazda 3
Dittoz7 wrote:Does This Raise Hp Numbers In Anyways?
mainly shifts the power band higher, but it also pulls harder than it normally would.
Dittoz7
So Lets Me Get This Straight.
S14 KA = 248/248
S13 KA = 232/232
So I Doesn't Matter Which S13 323 Cam (Exhaust/Intake) I Take, As Long As I Put It On The Correct Side On My S14 KA. (And Set The Teeth Back 4 YadaYadaYada...)
DMan II-40
Car: 1995 240SX SE
No that's wrong. S13s are 240/248 and S14s are 232/232. So you NEED the exhaust cam of an S13 to do the swap. And yes 4 teeth CCW. If you search there is a thread where this guy did all the different combination and he liked 248/232 the best (besides re-drilling which is to much work for me)
numbnuts240
2011 Ford Focus
2010 Mazda 3
dman beat me to it.
here's teh thread where all the combos are tested
zer...age=1
Dittoz7
Ha, Just Testing You Guys...
silverkaturbo
Car: 91 Nissan 240sx
Did any of you guys redrill your intake cam gear? Will it really change much? I mean, if its just marking a hole and drilling it i think thats what Im gonna do anyway.
sommmatt
Cam probably broke because it was dropped, or something was dropped onto it, at one point.
I was doing work on an RB25 car, which had a knocking motor, so the asian kid who owned the car sourced me another motor and I put it in. Ran great, drove around for an hour, and then the cam broke at the gear on the exhaust side, all of the exhaust side valves smashed. I raged hard.
Then spent a weekend swapping heads from the old blown motor.
One happy asian kid.
numbnuts240
2011 Ford Focus
2010 Mazda 3
silverkaturbo wrote:Did any of you guys redrill your intake cam gear? Will it really change much? I mean, if its just marking a hole and drilling it i think thats what Im gonna do anyway.
why? it's just extra unnecessary work if all you want is the cam swap.
sommmatt wrote:Cam probably broke because it was dropped, or something was dropped onto it, at one point.
possibly, but that's the risk you take buying used parts. i got really lucky in that the motor didn't take any damage. really REALLY lucky.
silverkaturbo
I take it you didnt read that thread then... nevermind i guess. Basically an exhaust cam isnt designed to be used as an intake cam. Yea, rotating it a few teeth makes it so it runs and works pretty well, but the overlap can definitely be improved upon. A few degrees advanced or retard here and there (way more specefic than just the spaces between gear teeth) can make a difference.
Basically it seems you're not taking full advantage of the swap because 4 teeth doesnt let the valves open and close at the optimum time. -2.5 degrees from the original pin location is what people have found to be the best angle. Might as well get the most out of it, and since its just a template to print off from JWT and a hole to drill, Im drilling mine.
numbnuts240
2011 Ford Focus
2010 Mazda 3
gotcha. maybe i'll get to it one day, but at the time i was more concerned with not needed to rebuild my head/replacing it. also, my car is strictly on dd status, so milking the cam swap for all it's worth is not a high priority for me.
motoman399
Car: 98' wrecked (RHD coming soon) 240
yes i did this on my friends before we got his timing corrected. when we got his timing corrected we put the gear on the stock position. its very easy to drill the gear. cant say weather it works or not though. let us know what you find out.
