210K mile OE S14 radiator + 1.1bar cap for 3 years = BAD JU JU
Hijacker
Car: '92 240sx Convertible
'94 F-150
That's pro Ian!
IanS
Car: 2002 Subaru WRX, 2010 Subaru Forester XT, 2004 Infiniti G35 Coupe.
Well, with the car out of commision, Ive decided to do something Ive been wanting to do for a very long time now. I got down and dirty, and started tucking all the wires around the intake manifold.
Im rerouting the MAFS and CAS wiring, as well as the signal line for the BOV around the back side of the engine. That way they wont be hanging right off the front of the valve cover looking all ghetto.
Im also going to run the injector, ECT, and IAC wiring under the intake runners. This way they wont be laying on top. This should give my bay a cleaner look.
I started by cutting all the ties holding the wires everywhere. Then I stripped the old tape off the injector wires, and I seperated the CAS wiring from the ECT/IAC.
If I have time tomorrow, I will loom and tape everything back up. Then I will route, and attach it. Hopefully I can finish up before my radiator shows up on Wednesday.
S133P3R
Car: 1989 S13 240sx
Hijacker wrote:That's pro Ian!
hell yeah, ian is a pro! thanks for the digits btw and good luck with the new radiator and wire tuck.
sloweighty
Car: sileighty
slyedog240sx wrote:Have you contemplated going with g05 or just straight green.I love the go5 for not only the extended life but also the color being basically clear allows you too see any problems very fast.Also what was the point of running a 3psi higher cap? That needed for a higher volume wp or the sr in general.Watter wetter shouldn't harm coolant levels whatsoever but my understanding is it's main purpose is for peolpe running straight water to get better cooling. I don't think it benefits antifreeze any.
Modified by slyedog240sx at 6:04 PM 6/11/2009
Modified by slyedog240sx at 6:07 PM 6/11/2009
yea man i love this stuff.....my coolant system only has ten percent of this stuff, redline wetter water, and the rest is just mineral free water and my car is rust free and runs cool
IanS
Well, everything showed up a day early, but I worked all day, and had no time for install. I will have to wrap up the wiring tomorrow, as well as install everything.
IanS
All the parts are in. Everything looks good except my jury rigged coolant reservoir no longer fits. It looks especially ghetto right now. Guess its time for something custom, and metal.
