VStar650CL »
https://forums.nicoclub.com/vstar650cl-u299034.html
Mon Feb 15, 2021 3:38 pm
First, problems like this are almost never the dash controls, so quit worrying about that. Take a look at the compressor with the AC switched on and see if the clutch is spinning.
If it isn't: If the compressor fuse is good, you have one of four things, low freon, a bad freon pressure sensor, a dead compressor clutch, or one of the three AC temperature sensors (ambient, in-car or inlet) is making the BCM think the car is in Alaska. The ECM won't let the compressor turn on if refrigerant pressure is low, that's why low freon or a bad sensor can cause the issue.
If it is: You may have a bad swash plate in the compressor. Nissan uses variable-displacement compressors on the gen2 Rogue, and the swash plate is the part that varies the piston throw to make the compressor output more or less volume per stroke. It's easy to diagnose a bad swash using the blower control in the car. If the system outputs good cold when the fan is on low-low, but quits blowing cold when you dial it to high, the swash is stuck and you either have an open connection to the swash solenoid (on the compressor) or the swash is dead and you need a compressor.
