2014 rogue select speaker wire colors
OMAR6575
Car: 2017 NISSAN PATHFINDER S 4WD
hi,
i need some help, i have a 2014 rogue select and i want to add an amp. however there is a small problem, the speaker wire colors in the back of the speakers do not all match what s behind the radio, no only that. the colors that do match (the rear) are some how loop or are in two different harness in the back of the radio. adding an amp to this radio has become a real pickle. to my understanding what normally was a simple to the point task has become a total nightmare.
has anyone experience this :confused:
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
You have a 2014 Select, which is a first generation model. There's already a ton of stuff posted here about stereo upgrades.
Start by doing a SEARCH in this forum for speaker wires. Her's a partial list of what turns up:
post6638612.html
how-to-make-your-rogue-go-thump-thump-t ... 71349.html
2013-rogue-radio-wiring-diagram-t577410.html
post6456342.html
post6450428.html
Also, there's an entire section devoted to upgrades: ROGUE DIY REPAIRS & MAINTENANCE, FAQ & INFO, TIPS, etc
Finally, you can use the 2013 FSM for additional info: http://www.nicoclub.com/FSM/Rogue/2013%20Rogue/
Return to “Rogue Forum”
