mcheddadi »
https://forums.nicoclub.com/mcheddadi-u65598.html
Wed Feb 11, 2009 8:43 am
who has an extra 23K? cuz thats the new DIRT CHEAP price of the 2.0T R genesis coupe. check it out, hyundai is totally gets it sooo much lol they even mention its an easier model to pimp by the tunners lol!
PRESS RELEASE
Hyundai Debuts a HIGH–PERFOMANCE BLANK canvas for tuners: Genesis Coupe R-Spec
CHICAGO, Feb. 11, 2009 – When the colors of your new turbocharged rear-wheel-drive sport coupe are named after international racing circuits, you'd better have the performance and confidence to back it up. Now, Hyundai is upping the ante by announcing an R-Spec version of the all-new 2010 Genesis Coupe, designed to appeal to true enthusiasts who want a low starting price and the ability to tune their car to their own specifications. R-Spec will be available as a mid-2010 model year introduction.
R-Spec provides genuine track-readiness in an affordable model. The R-Spec adds core performance equipment to the most affordable 2.0T model, such as: Track-tuned suspension, 19-inch gunmetal-finish alloy wheels with performance summer tires, Brembo® braking system, Torsen limited-slip differential, and R-Spec badging. To further reduce cost and weight, it also eliminates some non-essential convenience equipment such as: Bluetooth®, automatic headlights, cruise control, trip computer, chrome interior accents and steering wheel audio controls. The Genesis Coupe R-Spec will be priced at $23,750 and $3,000 less than the 2.0T Track model, leaving tuners with extra cash for their own choice of aftermarket performance upgrades. Appropriately, the R-Spec will be available in three performance oriented exteriors colors: Karussell White, Bathurst Black and Tsukuba Red.
R-Spec equipment includes:
* 2.0-liter low-pressure turbocharged intercooled four-cylinder engine with dual continuously variable valve timing delivering 210-hp, an estimated 30 mpg EPA highway rating and a top speed of 137 mph * 6-speed close-ratio manual transmission * Electronic Stability Control with Traction control, ABS, Electronic Brake-Force Distribution and Brake Assist * 19-inch gunmetal-finish alloy wheels with staggered-width high-performance summer-compound Bridgestone Potenza RE050A tires (225/40YR19 front, 245/40YR19 rear) * Brembo® braking system with 13.4-inch ventilated front rotors, 42mm four-piston fixed front calipers (red), 13.0-inch ventilated rear rotors, 32mm+28mm four-piston fixed rear calipers (red) * Track-tuned suspension (higher-rate coil springs, higher-control shock absorbers, 25mm front stabilizer bar, 22mm rear stabilizer bar, front strut brace) * Torsen-type limited-slip differential * R-Spec badging * Quick-ratio hydraulic steering (2.7 turns lock-to-lock) * Tire Pressure Monitoring System * Front, side, side air curtain air bags * Active front head restraints * Driver's lumbar support * Air conditioning * Remote keyless entry system * Leather-wrapped steering wheel and shift knob * Power windows (one-touch up and down), door locks and mirrors * AM/FM/XM/MP3/CD audio system with six speakers * iPod/USB/Aux jack connectivity * Projector beam headlamps * Lightweight temporary spare with aluminum wheel (T135/80D18) * Note: Automatic transmission not available with R-Spec (f*** YEAH!)
