Travis Burelle / Forced Induction RacingVQ swaps, Engine builds, Turbo kits, Chassis work..985-713-1542 (www.fi-r.net)
trav4011 AT hotmail dot com
http://myspecv.net/f/t185591-f....html
Trav4011 wrote:After a year of searching, we have finally made solid arrangements to begin testing for our turbo kit for the 2007+ base SE-R and Spec V platform.
We will begin fabrication in mid July, with testing to start in late July through mid August. This kit will be designed/built with top notch parts, including the following..
TIG welded 304L stainless manifold [h]with 4-1 collector (NOT a cheap log manifold)[/h]TIG welded 304L stainless FULL 3" downpipe and midpipeTIG welded, polished aluminum intercooler piping kit Bar/plate intercooler core with TIG welded/polished end tanks (size yet to be determined)T-bolt clamps and 3 ply silicone couplers Tial 38mm waste gate with dump tubeGarrett 50, 57 or 60 trim turbo (your choice), or, upgrade to Precision SC61 (+200.00)3" polished aluminum inlet pipeStainless braided oil feed and drain lines, plus fittings, bolts and flangesGreddy Type S BOV42lb injectorsApexi SAFC IIAll vacuum lines/hoses, clamps includedWalbro 190lph fuel pump (255lph upgrade free option)
Just to give you an idea of the type/quality of manifold that we will be using..
You will be able to choose between 3 different T3/T04E Garrett turbochargers, including a 50, 57 or 60 trim compressor, and T350 turbine. Housing choices will be .48, .63 or .82 A/R T3 for the turbine side.. and .50 or .60 A/R on the compressor side. As an upgrade, we will also offer a Precision SC6176E for an additional 200.00.
Garrett Unit:(Photo: courtesy of Phoenix Turbo)
Precision Unit:(Photo: courtesy of HP Freaks)
In addition, we will be using authentic Tial and Greddy products.. to ensure reliabiliy and sound performance.
All fabbed parts will come with a lifetime warranty, against cracking.. ALL hot parts will be fabbed up from 304L stainless, to ensure a great look, and solid performance.
Our goal is 285-325whp, for our base kit, at stock boost pressure. The kit itself will have the potential to make anywhere from 400-600whp, depending on which turbo you decide on.
We are aiming for a retail price of 3995.00, and plan to do a group buy once testing is complete, and production is ready to commence.
Check back frequently, as we plan to hit this hard next month.. with results by early/mid August.
Travis
