Header > HeadersShift_Altima wrote:Loud bc of exhuast.. headers.. bolt ons. Not from extra psi.. Is it worth getting a SpecV turbo.. putting a catback and turbo back and boosting like 7 psi? I just don't wanna kill my engine and as we figured out in this thread.. the qr engine isn't the most turbo firendly around.
sry for takin up so much of everyones time. im just really interested in the forced induction idea but pretty cluless about it
If you don't want to dump pollutants in the air, don't buy a turbo system. With the added fuel and tunning involved with a turbo you will be running rich to avoid detention/knock. Which in turn will produce a lot more pollution. Also if you have to pass a smog inspection, you shouldn't get a turbo, because you won't.Shift_Altima wrote:I'm not changing my engine's internals bc thats a HUGE waste of money. HUUGEEEE WASTE. So on stock internals we agreed that 7 psi was the maximum that would be safely added. If driven like a normal car without pushing often.. u know having fun occasionally how long would this last on stock internals? No way im taking out my catalytic.. I won't pass inspection and I don't wanna dump toxic stuff into the air.. thats just stupid. Ya i figured a custom exhuast would be needed but I don't know how lol.. Where do u get a downpipe and is it absoltuly neccesary for the turbo to work? Lol I already love and care for my car no need to worry.. And as for research. along with u guys.. im doing alot on my own but I'm trying to clarify alot of things i'm iffy about. thanks again for the time i really appreciate it..
The downpipe will bolt to a flex pipe that bolts to your exhuast piping. The flex pipe is what allows you to get the fitment just right because it "flexs" and moves slightly so you can bolt up both sides correctly.Shift_Altima wrote:Lol ok whatever about the environment lol. I talked to the guys at turbo-chargers.com where our other guy is getting his donw. The kit comes with a downpipe but ti's for an SER so fitment might be a challenge but it can prob be done. He said everything except for exhuast will be in that kit. So i've got no more quetsions about the actual kit but as for the exhuast.. what do i need to do and how will it work? I also talked to a guy at a nissan dealership who's on these forums. He told me the stock internals are upgraded adn the rods are stronger on the new qr and the SER engine is the same thing. The only reasons its pushing 200 is the compression rate is higher for the pistons and the ecu is t uned differenlty. He also said 7 psi is very safe.
True. I was thinking in terms of there being a big cat back available already. But of course, there isn't, and my bad there. For the record, I've never had a turbocharged car, so I'd listen to what adidas2go has to say. Anyway, maybe by the time you decide to add a turbo, there will be a larger diameter cat-back available. But for now, yes, go to a muffler shop to get a custom exhaust. If you want the car to last 100,000 miles, I would strongly suggest investing in stronger internals, no matter if the stock parts are stronger than they used to be. You will get your money's worth. And if you do, you can get more power. Anyway, 7-8 psi on stock internals should be safe as long as you don't push the engine hard every day.adidas2go wrote:...First of all, you WILL absolutely need a custom exhaust. You are not going to be pushing 300 F/I hp on 2 1/4 inch piping. You will defiantly need to upgrade to 2 3/4 or 3 inch to maximize the air flow the turbo will thrive on...
http://www.importperformancepa....htmlgo to the end of the pageits $949Shift_Altima wrote:I'm not sure where to get forged internals. The most i'm gonna do is forged pistons because that's the weak point in the qr engines. As for forced induction.. i'll wait a few thousand more miles i guess and see what's going on. I'm def gonna take the advice from some of u guys and i really appreciate it. I guess as for this thread.. there's not much else to be asked except where the hell do u get forged internals?
It's a turbocharger with some pipes attached...Kind of cool haha. Sorry, I am in a joking mood this morning.TheBourneAltimatum wrote:^pics and list parts you used please
and when are you guys gonna make a QR pro for us? and does QR pro get rid of that ridiculous 112 mph limiter
