1unar3clipse »
https://forums.nicoclub.com/1unar3clipse-u51086.html
Wed Oct 22, 2008 6:40 am
Starter hump on bellhousing pointing down, then rotate it into position.
Get a jack and a a plank of wood, loosen your motor mounts a bit and jack the motor up from the oil pan SLOWLY (disclaimer: you can screw up if you forget to loosen the motor mounts or jack it up too high) so that the rear of the motor is aimed down a bit... that should make it a little easier.
The best advice I can give you in the end is: it seems impossible now, but once you get it in there once you'll be able to do it again without struggle.
