i posted in one of your other threads
1990-q45-gradually-over-2-months-cannot ... 81946.html
is most likely MAF or Crank Angle Sensor or related wiring and connectors. looks like you said the maf was replaced so if a good part.. leaves CAS. fuel pressure check is quite easy on this car can plug into the line past the fuel filter on the side of motor. also pull the vacuum line to the fuel pressure regulator at back of motor and look for fuel should pour out if bad.
Fuel System
Fuel Pump Pressure @ Idle
Vacuum applied at fuel pressure regulator 34 psi
Vacuum released at fuel pressure regulator 43 psi
from q45.org
Yesterday I tested the fuel pressure to find the following results.
1) Ignition on at 44 PSI.
2) After start up, pressure settled down to 34/35 PSI.
post
fuel-pressure-test-t504230.html
so 10psi drop is normal
fuel injector and knock sensor testing from q45.org
http://www.q45.org/ohminjectors.html
all injectors should read the same top the tenth of an ohm hot or cold or something is failing
unless you have a dead miss the injectors are okay and this will not limit rpms anyway trust me. drove on 5 cylinders around town for years since was my only car.
bought full set of injectors from rockauto by gb reman not sure if it worked out well; had a few soon fail. problem is engine plenum may have to be removed again to correct. new injectors are going for $685 full set oem on ebay.
http://www.ebay.com/itm/BRAND-NEW-GENUI ... 0965746376
some people have switched to the phase two they are a bit cheaper and quite possible a more reliable design is fairly easy swap i hear.
see
94-96-style-injectors-on-90-93-q-inform ... 99119.html (pics are gone maybe msg someone)
have had the phase I design them fail one after another and even in groups (used).
with a misdiagnoses and having things replaced on this car that are not broke gets expensive fast with parts and labor. car usually ends up with a mechanics lien, gave up on, or results in more problems than before and a broken car. when under the plenum to not change the knock sensors and related harness would be a shame. bad ks or harness drops engine power by a third.
tidbit from post in other thread "CAS has secondary mode when primary mode fails will limit engine rpms as well. would not put used parts on this car it will usually not work out well."
FSM source now with earlier models http://www.nicoclub.com/FSM/Q45/
best wishes
