Fuel Pressure Test
OwnerCS
Yesterday I tested the fuel pressure to find the following results.
1) Ignition on at 44 PSI.
2) After start up, pressure settled down to 34/35 PSI.
I found the hoses to be in surprisingly good shape. It really says a lot for OEM hoses that are now approaching 20 years old.
Pictures are posted below.
loystock
Car: 10 Honda Pilot
97 Infiniti Q45
03 Infiniti Q45
97 Infiniti I30
06 Infiniti M35 Sports
04 G35 & 99 I30-RIP
Very nice and clean engine compartment. And your fuel pressure is very close to ideal (43/34 PSI).
goody90q45
Car: 1992 Infiniti Q45 (sold)
Super looking engine compartment. If Maxnix was with us I'm sure he'd be able to spot something that needed fixing. It doesn't take much to keep it clean once you've taken the time to get it to this point. :gapteeth:
lino
Car: 1991 Q45a Fed-Spec, IQP/White, Texasoil 9 Accumulator Recharge, '93 TCU 1st Gear Start, JWFSB, B&M 70268 Transmission Cooler, BBS Forged Wheels, DRLs, Silverstars, Tint, Very Well Serviced.
Excellent results, beautiful engine compartment, and thanks for sharing :) . You plenum looks shiny :cool:.
Q451990
goody90q45 wrote:If Maxnix was with us I'm sure he'd be able to spot something that needed fixing.
OK... (channeling Maxnix) :nono: Time to flush that brake fluid (Maxnix off)
Seriously... that engine bay looks prisine! And I would flush that fluid to try to preserve the seals on your ABS actuator. They're prone to leaking on the early Q45s.
Heath
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
goody90q45 wrote:Super looking engine compartment. If Maxnix was with us I'm sure he'd be able to spot something that needed fixing. It doesn't take much to keep it clean once you've taken the time to get it to this point. :gapteeth:
He is missing the OEM battery box, red rubber postive cable end cover and the shock tower bolt covers (Made of plastic). Oh and looks like he put in a new negative battery lead on the cable.
I am only kidding its a fantastic engine bay! :)
OwnerCS
LOL - Thanks guys! For bleeding the brakes, will one of those vacuum pumping brake bleeding "one man" operation gadgets do the job?
goody90q45
Paul Wall wrote:.......He is missing the OEM battery box, red rubber postive cable end cover and the shock tower bolt covers (Made of plastic). Oh and looks like he put in a new negative battery lead on the cable......
....and for Brian because I know he's lurking....the rubber boot over the hood open/closed plunger (by the MAF) is missing.
I have a couple of the shock tower bolt covers (plastic disks) if you'd like them. PM or email me.
qship96
Car: 1996 Infiniti Q45
What happened to Brian {maxnix}, have not seen him post for ages????
Q451990
I received an email from him a couple of weeks ago. One of his Qs had an engine-destroying hydrolock experience from a leaking lower o-ring. He asked me to reset his password, and did, but I haven't seen him post yet.
Heath
loystock
Car: 10 Honda Pilot
97 Infiniti Q45
03 Infiniti Q45
97 Infiniti I30
04 G35 & 99 I30-RIP
I hope the engine survived. I learned a lot from Brian and Dennis about the Q.
Lokim
Car: 1994 Infiniti Q45 acquired 4/25/10 w/192K
Now at 222K and going strong!
Q451990 wrote:I received an email from him a couple of weeks ago. One of his Qs had an engine-destroying hydrolock experience from a leaking lower o-ring. He asked me to reset his password, and did, but I haven't seen him post yet.
Heath
Boo! :frown:
lino
Heath
What a shame :frown:
Q451990
loystock wrote:I hope the engine survived. I learned a lot from Brian and Dennis about the Q.
He mentioned a hole in the side of the engine. :(
qship96
I have exchanged emails with Brian, and knew about his Q troubles- but still cant figure out why such an active member dropped off the boards.....thought maybe I missed something? Seems like traffic here has dwindled to almost none since the forum switchover thing happened?
