Okay you edited your post a little bit since I last read it. At least the graphics is a little bit different. Rememebr that the distributor runs at half the angular speed of the crank due to the fact that it is mapping an actual 720 degrees of crank rotation to 360 degrees of rotor rotation (i.e. when the "clock" goess from 12 to 12, the crank has really travelled 720 degrees).mtcookson wrote:You are correct that 1 and 7 are 180 degrees apart, but that is at the crank. My picture is depicting a distributor (if the VH were to have one) where 1 and 7 would be 90 degrees apart in the distributor.
In my picture, cylinder 1 fires and 180 distributor degrees later 6 fires (this is 360 degrees of crank rotation). I'm pretty sure this is what they aim for to get the 180 degree separation.
I'm not sure if I can explain it very well but here's another thing that makes a bit more sense to me, you made note that with the numbers you had there are other pairings of numbers... if you take my example you will never have any other pairings, which makes much more sense to me.
Also, the bigger thing that makes me think its right is I'm basing it off of this site: http://www.rocky-road.com/thorley.html
I don't know if that site is correct either, but I've thought through the different scenarios and this one definitely makes the most sense to me.
i have my engine moved back long time ago..... very back...... .David Steele wrote:I remember some ******* flamed me when I spoke of pulse converter manifolds for a twin scroll turbine housing.
8-4-2-1 manifold going off a 90* firing order.
I can only see this happening for people who move there engine back in there engine bays.
i guess:some hp? not muchmore linear torque? a little more torque also?a high pitch ferrari exhuast sound? (this is what i like most..)others??? not too sure...Mettler wrote:It all seems like a lot of effort for minimal gain... you can use an X or H pipe just after your headers to equalise pressure across both manifolds... I realise it's not the same thing though.
What realistic gains do you guys hope to see with such a setup? Good luck with your fabrication nightmare! :p You'll have to be damn good to get all the runners equal length and to have smooth bends!!
Yeah, that's kind of crap. The pulsed manifolds are definitely proven to be much, much better than constant pressure when it comes to a turbo. If you can do them, they're most definitely the way to go.David Steele wrote:I remember some ******* flamed me when I spoke of pulse converter manifolds for a twin scroll turbine housing.
Yeah, I added a few lines and changed the colors to make it a little more understandable. Other than that its the same picture.SSDwellah wrote:
Anyway, here is another link about this topic:http://home.alltel.net/bsprowl...s.htm
I am not 100% sure and I have said my $0.02 so I will defer to the experts
Actually in a twin scroll turbine where 180 separation is required it's not dimensionally insane because :T45 wrote:I have to go with Mettler on this one and say that the work involved outweighs the benefit. If you put a VH in a sandrail or something then it would be easy. In a car it's just silly.
so all you have to do is pair 1-7, 3-5, 8-2, and 4-6? That doesnt seem like itd be any harder than making regular headers...David Steele wrote:
180* Separation perfectly Bank 1 1-7/3-5 - Bank 2 8-2/4-6 .
Very much possible sir for a single turbo configuration using V-band to joint the two tubes together. That'd be the 4-2-1 .
There can be a vacuum on 1 the 1-7 group merges with #2 bank 6-4 on the VH and then 3-5 merges with 8-2 to get a low pressure signalmtcookson wrote:
If you pair 1 and 7, the exhaust of cylinder 1 should put a vacuum on cylinder 7 causing the scavenging effect but 7 will not do the same for 1 as there is too much time between events.
Thats what a Ferrari flat plane sounds like with there 180 degree spacing.Dohc engines sound alot smoother though. That was a rusty dodge engine!T45 wrote:Sounds like a 4 banger to me. I am betting the Vh would sound better though. hp?
