Your banks are reversed. Odd are left, even right. Hence your 7 and 8 are actually correct.doctorchee wrote:PLEAES CONFIRM THIS below
VH41DE
radiator fan 2 1 4 3 6 5 7 8 flywheel
thanks everyone...
Regrdsderrick
Those cars and the early Le Mans Ford V8 had exhaust in the middle of the V and intake on the outside, so it was a lot easier to execute the "bundle of snakes" exhaust. Tough to do on a motor designed with the intake valves inboard side of the heads in the V configuration like most street engines.SeanDean wrote:There's actually an easier way of doing this guys, especially for you doctorchee...
Let me go and find some pictures of 60's Grand Prix motors to demonstrate.
It's pretty unconventional, but I think it's exactly the kind of thing you will be into doc!
Hi thanks a lot for your info.maxnix wrote:Those cars and the early Lemans Ford V8 had exhaust in the middle and intake on the outside, so it was a lot easier to execute the "bundle of snakes" exhaust. Tough to do on a moter designed with the intake valves inboard like most street engines.
Thats pretty intense Van, please try and find those pics!!!one ton garage wrote:Wow I'd never seen this thread before.. not sure how I missed it, as this is always a very cool topic. Just wanted to throw an FYI out there... original Ford GT40s ran 180deg/paired headers, so it's not uncommon to see a number of GT40 kit cars/replicas with paired headers on their Ford and Chevy small blocks... BUT... in the mid- to late-90s there was a company in Japan that made GT40 replicas using VH45s with 180deg headers. I heard they did sound awesome, and I had a pic of one somewhere, but can't seem to find it. Afaik, the company might no longer be in business unfortunately...A real GT40 restored:
I'm using an Autronic SMC and CDI. It has less auxillary outputs so you need to control some things without using the ecu but gives very good tunabilty and reliabilty.If I was making the choice between SM2 and SMC + CDI then for boosted the CDI is a big advantage and it gets rid of the factory ignitors etc so simiplifys wiring. I'm using thermo to control fans, and will be using a frequency switch for the cams (when we start switching the cams). The ecu is control boost but otherwsie it only does engine functions.doctorchee wrote:
thanks a lot pal.
yes it will be swivelled or rotated. i actually try to put the turbo higher so as the oil can be reutrn via a higher attitude.
you are sharp... thanks.
will update more photo next week.
now busy looking for a ECU. properly a autronic Sm2. a used 1 would be perfect.. $$$ running low fast...
